Low idle on my R ... What's wrong ??
Old Jun 4, 2002 | 12:21 PM
iperez's Avatar
Default Low idle on my R ... What's wrong ??
Guys, my 2001 ITR which idled normally at 750-1000RPMs all the time is now occasionally idling at 450RPMs. This happens particularly when its hot outside, for instance, if I park the car at work and use it to go and get lunch when its hot outside. The dealer says its normal but I don't quite agree. Any suggestions ??
Old Jun 4, 2002 | 12:25 PM
kitkatR's Avatar
Default Re: Low idle on my R ... What's wrong ?? (iperez)
man my car idles at 200 rpm when it is hot but i have seen no problems yet
Old Jun 4, 2002 | 12:46 PM
iperez's Avatar
I've seen no problems myself either and yes, my R has gone as low as 200RPMs at times. Its just weird. This is my 3rd DC2 (I had two non-VTEC Integras before the R) and those had a very steady idle.
Old Jun 4, 2002 | 12:53 PM
smkngsr's Avatar
i had the same problem too... my volt guage will go to 12v and the idle will drop to 400-500 and as i drive for a while when my voltage goes up to like 13-14v my idle will go back to 750-850-..hope tis is normal too...i havent found the problem yet...hope its not something major...
Old Jun 4, 2002 | 12:55 PM
MPH's Avatar
MPH
New User
Mine idles really low and stalled numerous times at the drag strip the other day but I have a Hondata that's obviously not working correctly.
Old Jun 4, 2002 | 03:37 PM
itr98spec's Avatar
Default Re: Low idle on my R ... What's wrong ?? (MPH)
my car idle low too, but after some hard driving, the car idle at 1000rpm? any reason why?
Old Jun 4, 2002 | 05:32 PM
HondaRcB's Avatar
Default Re: Low idle on my R ... What's wrong ?? (itr98spec)
My 98 Type R does the exact same thing as iperez's. Only when it's hot outside. It has also cut off on me before, usually once when driving the car right after it's warmed up, after that it doesnt stall again. Any ideas anyone? It always starts back up and runs great when on throttle so I don't really worry about it.
Old Jun 4, 2002 | 05:49 PM
Junglist's Avatar
Default Re: Low idle on my R ... What's wrong ?? (HondaRcB)
idle jumps from 1000-750-1000. i hear the fan go on when it happens. I think its when the AC or the radio are on...maybe.
Old Jun 4, 2002 | 06:08 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: Low idle on my R ... What's wrong ?? (Junglist)
Idle stays around 500. But when I puit my lights on it goes back to to normal. SO i just drive around with my lights on all day like a ricer Untill I can figure out whats wrong with it
Joker88
May 15, 2017 07:14 PM
Tillerdrums88
Jan 14, 2013 07:55 PM
ddubtoille
Aug 13, 2008 02:39 PM
bb4 jdm lude
Mar 12, 2008 09:25 AM
raene
Nov 7, 2002 08:21 PM
