mad idle surge
Old Jun 8, 2007 | 08:05 AM
sprayinBseries's Avatar
Default mad idle surge
i have a 91crx HF with a d16z6 in it
ive always had a small idle surge
recently my alternator went out
i replaced it and now the idle surge has gotten worse
i checked vacumm lines i found that the FPR was unplugged
i plugged it back in and it settled down a bit
but its still worse than it was before i replaced the alternator
any help is much appreciated. thank you
Old Jun 8, 2007 | 08:46 AM
inspyral's Avatar
Surging idle is usually associated with a vacuum leak or air in the cooling system. I would start by doublechecking all your vacuum connections and rebleeding your cooling system and then go from there.
Old Jun 8, 2007 | 10:40 AM
chicows18's Avatar
Default Re: mad idle surge (slammedeg693)
If the idle goes up and down it could possibly be the idle control valve located behind the intake manifold. This has a black housing solenoid in it an utilizes one plug with two water inlets. Disconnect, clean with carb cleaner and blow out, and reinstall. If this doesnt work, then replace. If the idle just stays high and you cant regulate by distributor or idle control on throttle body, then check your throttle body for the two water lines right under it. This utilizes a pressure system and if it malfucntions, then it needs to be replace. Its right under your throttle body and its held on by 3 10mm bolts.
Old Jun 8, 2007 | 03:56 PM
Default Re: mad idle surge (chicows18)
thank you for the advice ill check that stuff out.
da9crxsi
Jun 4, 2012 09:52 AM
1991civicb16
Jul 16, 2011 12:38 AM
averyvm
17
Jan 17, 2007 11:51 AM
PWRDbyHseries
Oct 18, 2006 05:44 PM
94SHOWLS
Feb 17, 2005 12:31 PM
