SI Transmission
Old Jun 8, 2007 | 07:12 AM
dra600n's Avatar
Default SI Transmission
Here's the situation:
New engine: D15b in, runs, etc. Haven't driven it yet as the transmission needs to be filled with oil. The problem is that the filler/release bolt won't come out. What is the alternative way to put oil in the transmission? Through area where the CV Shaft connects? If so, will I need to jack the car up at an angle, or will I be able to fill the tranny while its level?
Thanks
Old Jun 8, 2007 | 07:33 AM
jlicrx's Avatar
Default Re: SI Transmission (dra600n)
you can remove the back-up light switch on the top and fill it thru that hole - hole is small, but it can be done - uses 1.9 quarts (if it is completely empty)
Old Jun 8, 2007 | 07:42 AM
Super79Dave's Avatar
Default Re: SI Transmission (jlicrx)
You can also fill it through the speedo cable hole.
Old Jun 8, 2007 | 07:43 AM
dra600n's Avatar
Ah, excellent, thanks for that info!
nocturnaldragon
44
Jun 18, 2014 03:59 AM
Jackknife
Transmission & Drivetrain
Aug 24, 2013 09:42 PM
3lo
12
Oct 17, 2007 05:59 PM
d4rksid3
Jun 21, 2007 06:36 PM
tigueremalo
46
Jun 1, 2006 06:06 PM
