Oversized Injector Question
Old Jun 7, 2007 | 03:07 PM
freeshot350's Avatar
Default Oversized Injector Question
i have a 00 si b16a2. and im planning on buying 310cc injectors but im worried maybe too much. do the injectors only use as much fuel as they need or are they set at a certain point? will i overfuel? have minor bolt ons Skunk2 manifold 66 mm throttle body. borla cat back k&n intake magnecor wires iridium plugs any help would be appreciated
Old Jun 7, 2007 | 04:12 PM
Default Re: Oversized Injector Question (freeshot350)
bump
Old Jun 7, 2007 | 04:40 PM
doood's Avatar
been there done that
unless the ecu is tuned for those particular injectors it will run rich
why do you need bigger injectors? stock 240cc's are good up to 190whp, sometimes more.
Old Jun 7, 2007 | 05:14 PM
i dont need bigger ones i just need new ones. and i can get a good deal on the 310cc.
Old Jun 7, 2007 | 05:21 PM
97Ej6mike's Avatar
310cc seems kind of overkill for the motor unless you are running boost, or a very built (all) motor. Since you have an aftermaket Manifold, and arent boosted, the stock 240cc injectors would work just fine, although i have read that people have had success using 270cc injectors with aftermarket manifolds. As stated before, the stock 240cc ones will do just fine for up to around 200hp.
Old Jun 7, 2007 | 05:22 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freeshot350 &raquo;</TD></TR><TR><TD CLASS="quote">i dont need bigger ones i just need new ones. and i can get a good deal on the 310cc. </TD></TR></TABLE>
How are you sure you need new ones?
Old Jun 7, 2007 | 06:22 PM
well my car is running like crap and when i did the manifold the injectors were pretty dirty car has 110k on it. so i figured screw it might as well replace them. another question does anyone know where the hell the timing jumper is on the ek? all the info i can find is for eg's
Old Jun 7, 2007 | 06:24 PM
Ek Forever y0!
https://honda-tech.com/zerothread?id=1951304
~$60.
They'll come back like new.
Old Jun 7, 2007 | 06:28 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1951304
~$60.
They'll come back like new.</TD></TR></TABLE>
right on. i was just looking for that myself.
Old Jun 7, 2007 | 06:36 PM
sauceja's Avatar
Default Re: Oversized Injector Question (doood)
Yep I was the April winner and holy ****. Those guys are good. Came back looking new and had a weekend at the spa.
2 of mine were real bad and 1 didn't make it back all the way I think it ended up at 238.
Good enough for me. Unless you can get RC's 310 for 150.00 shipped new then not a good deal for right now.
Old Jun 7, 2007 | 07:26 PM
Default Re: Oversized Injector Question (sauceja)
well my car is my only means of transportation i cant send my injectors away even for a couple days. thx for the info tho maybe ill see if i can find some new oem injectors.
Old Jun 7, 2007 | 07:38 PM
sauceja's Avatar
Or just find a spare set and send them off for cleaning and then install and send old set off for cleaning for a ready to go backup.
baggedd50
13
Mar 4, 2012 12:58 PM
totsie7944
Mar 3, 2008 07:09 AM
bird00420
May 10, 2007 08:50 AM
evo
Mar 16, 2003 05:43 AM
5gen-hybrid
Jan 13, 2002 10:45 PM
