crankshaft pulley problems
Old Jun 7, 2007 | 06:39 AM
vaughn83's Avatar
Default crankshaft pulley problems
am workin on my 94 honda del sol non-vtec SOHC and I bought this book for my car, what i need to know is... Is the crankshaft bolt threaded in a different direction then basic bolts? thanks for the help guys
Old Jun 7, 2007 | 06:47 AM
Padawan's Avatar
Darth ModerVader
Default Re: crankshaft pulley problems (vaughn83)
No, it's standard threaded.
Old Jun 7, 2007 | 07:09 AM
vaughn83's Avatar
Default Re: crankshaft pulley problems (Padawan)
whats the trick to taking this bolt off, cause am tryin to change out my water pump and timing belt. thanks for the help
Libertariat's Avatar
Ek Forever y0!
You'll have to hold the crankpulley stationary then use a wrench/impact to loosen the bolt.
Old Jun 7, 2007 | 07:12 AM
Padawan's Avatar
Darth ModerVader
A powerful impact gun paired with a good compressor has always worked for me. Many people will recommend the crank pulley tool and a breaker bar, but I find the air tools much quicker and easier.
Old Jun 7, 2007 | 08:46 AM
vaughn83's Avatar
When I get that off, what else will have to come off to get that timing belt on? I already took off the valve cover, took off the belts. The crankpulley was in the way of timing belt and the timing cover. I got the top half of the cover off. FYI the motor is still in the car.
I noticed that the motor mount is in the way of placing the timing belt on the cam and over the water pump and crankshaft? thanks for the help again man.
Old Jun 7, 2007 | 12:15 PM
tomatoe's Avatar
get the tool that holds the pulley, you can find them on ebay for like $30 shipped.
the mount will be in the way of the timing belt.
Old Jun 7, 2007 | 01:54 PM
Crazydave's Avatar
Default Re: crankshaft pulley problems (tomatoe)
You will need to support the motor, remove the motor mount (just enough to get the timing belt around it, remove the crank pulley, the valve cover, the two timing belt plastic covers, and of course the belt and water pump.
I would also use this opportunity to replace the valve cover gasket if it's hard and/or leaking, and it would also be the time to replace your other belts too.
be sure to pay special attention to the timing belt tensioning procedure. be sure to only turn the motor counter clockwise. You don't want your cam timing off.
Old Jun 7, 2007 | 04:29 PM
blk2mid2sol's Avatar
found this opposed to buying the crank pulley remover:
got it from this thread:
https://honda-tech.com/zerothread?id=1199463
works like a charm
a how to on changing the timing belt:
http://www.c-speedracing.com/h...t.php
should be similar to sohc
after a little reading you should be good to go
Pengo
11
Sep 2, 2009 09:57 PM
ohdannyboy111
Nov 19, 2007 06:41 PM
needVtec
Jul 4, 2005 12:19 PM
lunchboxEF91
Nov 17, 2004 09:00 PM
FourthGenHatch
May 23, 2003 02:12 PM
