how much can it handle?
Old Jun 5, 2007 | 06:04 PM
CeeJayy's Avatar
Default how much can it handle?
so i am putting ctr cams, toda cam gears, upgrading valvetrain and plan on chipping my ecu. redline is going to be around 9k -9.5k.. by the way the engine is a b16a2. how much will the bottom end be able to hold up? what are some reconmended items to change so that it will last longer? i also plan on changing the bottom end and doing a poor mans r or ls vtec later..
Old Jun 5, 2007 | 07:12 PM
doood's Avatar
been there done that
Default Re: how much can it handle? (CeeJayy)
lower the rev limit to 8200-8500 cause ctr cams wont make power higher than that. then you dont have to worry about the bottom end taking a **** on you.
Old Jun 5, 2007 | 07:13 PM
hatchling37's Avatar
The B16 has a pretty good rod/stroke ratio for high revving. The stock rods and crank should hold up, but if you're ballin' you might as well put some forged rods and knife-edge the crank.
94trouble
Nov 7, 2009 08:50 PM
cbabyby
Mar 21, 2007 01:49 PM
Aaran
Apr 5, 2005 12:42 PM
EK9civicJDM
19
Apr 28, 2004 09:57 AM
The G2 Racer
Dec 21, 2002 10:04 PM
