Stock Swar Bar with ASR subframe brace
I tried searching but didnt find anything. I own a 00 Civic Si and was planning on purchasing the ASR subframe brace. My question is will i still be able to use my stock sway bar with the ASR subframe? Thanks
Re: Stock Swar Bar with ASR subframe brace (ke98248)
In the first post they used an aftermarket one and im guessing from the second one i will still be able to use my stock sway bar. Can anyone confirm this.
Re: Stock Swar Bar with ASR subframe brace (UrbanAdolescent)
The differences between the AfterMarket sway bars and original ones, (I believe) are just in the type of material used, paint color, and size of the sway bars. So I think you can, yes. Bump for confirmation though.
This is what I plan to do on my 97civic ex coupe.
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UrbanAdolescent »</TD></TR><TR><TD CLASS="quote">In the first post they used an aftermarket one and im guessing from the second one i will still be able to use my stock sway bar. Can anyone confirm this.</TD></TR></TABLE>
You'll have to get Energy Suspension bushings and universal d-brackets. The stock d-brackets aren't big enough to match up to the bolt holes.
Energy Suspension Part #: 9.5152
http://www.energysuspension.co....html
Summit Racing Purchase Link:
http://store.summitracing.com/...w=sku
Re: Stock Swar Bar with ASR subframe brace (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
http://store.summitracing.com/...w=sku</TD></TR></TABLE>
x2. All you need is the bushings and d-bracket. Or you can go with a CTR or ITR rear bar and the stock brackets and bushings for those bolt right up. I did this to mine and used the CTR bar.
Eran even hooked you up with links for the parts, what a sweetie
kungfuSiR
11-19-2003 12:14 AM
