i need quick help
any got a write up of how to take LCR out of a 98 Civic? Im having trouble. One of the bolts is stuck. theres no nut, its a cylider pieice with 3 spot welds. How do i get this out! please help
Jesus Christ
OP - you've got to be smarter than this. Tell us whether or not it's front or rear, which bolt you're talking about and why you're having problems. We're not ******* mind readers. You can't expect "quick help" if you misspell the part you're needing help with and leave out all pertinent information related thereto.
Now, for your answer since you were too ******* lazy to search and find the answer in one of the 850 topics dedicated to this cause, you're going to want to cut the welded nut off the hub assembly so that you can remove the LCA from its perch. You can do this with an angle grinder, a sawzall, a Dremel (this would take forever) or you can drill out the spot welds. I, personally, use a reciprocating air hammer with a chisel bit, but you don't have one of those, so it's a moot point.
Once you have the LCA out, get all the bushings pressed out by a machine shop and have new ones pressed in. The bolt you're frustrated with is seized to the inner bushing collar. You would know all of this, by the way, had you searched before you started breaking ****.
Have a nice day, noob.
thanks dude, sorry i was in a ******* rush to finish my car to pick up my mom at the hospital. i am putting control arms in that have the bushing. And i didnt break anything pal. But then again i did say how do u get the bolt out that has the 3 spot welds on the suspension. i figured u guys did it a million times and knew wat i was talking about. thanks for ur help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Jesus Christ
Have a nice day, noob.</TD></TR></TABLE>
Can't we be a bit more civil than this...?
Purple-skunk
Mar 12, 2009 08:03 PM
IAcivicEK
Jul 27, 2007 08:26 PM
Got Utensils
11
Mar 10, 2004 06:37 PM
cdog19
Jan 24, 2004 06:13 PM
