RUSTED BOLT BY REAR LOWER CONTROL ARMS..NEED HELP...
yeah...i know this is common for all hondas to do this, but im currently in the process of raising my car with the stock springs and i raised the front already but then the back is giving meeh some problems...i just want to know if i need to get new shocks if the bolt is seized within the bottom piece of the shock....gimme some quick advise, cuz rite now im riding around in my car as if i got some hyrdolics on it...HELP!
Re: RUSTED BOLT BY REAR LOWER CONTROL ARMS..NEED HELP... (ekb18cCivic)
heat it with a torch and put wax on the threads then shock it with eather a hammer and a wrench or use a impact gun
Re: RUSTED BOLT BY REAR LOWER CONTROL ARMS..NEED HELP... (cstay)
i broke the head off mine last week when i was lowering my new car, be careful how you get it out
i had to cut the welded nut off the other end of my lca and replace the bushing, and bolt.
Munkyw3rkz.webs.com
1 Post
Re: RUSTED BOLT BY REAR LOWER CONTROL ARMS..NEED HELP... (shorty91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorty91 »</TD></TR><TR><TD CLASS="quote">i broke the head off mine last week when i was lowering my new car, be careful how you get it out
i had to cut the welded nut off the other end of my lca and replace the bushing, and bolt.</TD></TR></TABLE>
pretty much just drill that sucka out and replace it use 2 nuts ....easiest way adn works fine!!!!
Re: RUSTED BOLT BY REAR LOWER CONTROL ARMS..NEED HELP... (SnoFlake EG)
yep had to cut off my factory struts and get the bushing pressed out with the bolt still in it but yeah if your car bounces in the rear and is really loose.... you need shocks
Pooping on children
Re: RUSTED BOLT BY REAR LOWER CONTROL ARMS..NEED HELP... (Dx2dR95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dx2dR95 »</TD></TR><TR><TD CLASS="quote">yep had to cut off my factory struts and get the bushing pressed out with the bolt still in it but yeah if your car bounces in the rear and is really loose.... you need shocks
i did that but i dremeled out the bushing and pressed the new one in myself
thanx for all the input guys...immah fix the rear suspension prolly this weekend..
Re: RUSTED BOLT BY REAR LOWER CONTROL ARMS..NEED HELP... (Got Utensils)
heres a little trick i had to do once, If you land up rounding the head off of the bolt. I had to weld another nut to the bolt then beat the **** outta it with an impact gun (or maybe in your case a big wrench and a pipe )
dont forget the PB Blaster
puhlode
02-02-2003 12:24 PM
