teggy leaking
waz up guys i have a 1992 Acura Integra ls and recently i noticed a lil tiny spot of coolant,well actually everytime i park somewhere theres a tiny spot of coolant , i left the car running put in park and i noticed that it was leaking from the bottom like from the radiator i couldnt seen where but it wasw from under the radiator also my reservoir tank its always getting empty .....wat could it be .....thanks guys
It only leaks after 5 minutes because the pressure is building up and the water is still getting up to temp, it probably takes a couple minutes for your thermostat to even open. Your resivor is getting empty because your leaking fluid causing it to use the stuff from the resivor. Bottom line is, if its leaking from your radiator like you say than its your radiator, you need a new one or find out a way to ghetto patch yours up.
is there an easy way to check if is my radiator cause i look under the car and had the splash guard and it was impossible to c if it was from the radiator it come from the bottom of it but it could be a hose 2 dont u think.thanks
Prelude209
Oct 11, 2010 12:48 PM
