teggy leaking
Old Jun 5, 2007 | 08:20 AM
EJ7_1998's Avatar
Default teggy leaking
waz up guys i have a 1992 Acura Integra ls and recently i noticed a lil tiny spot of coolant,well actually everytime i park somewhere theres a tiny spot of coolant , i left the car running put in park and i noticed that it was leaking from the bottom like from the radiator i couldnt seen where but it wasw from under the radiator also my reservoir tank its always getting empty .....wat could it be .....thanks guys
Old Jun 5, 2007 | 08:47 AM
EJ7_1998's Avatar
Default Re: teggy leaking (EJ7_1998)
anyone'
Old Jun 5, 2007 | 08:53 AM
St Jimmy's Avatar
* B A N N E D *
Im going WAY out on a limb but I think your radiator could be cracked.
Old Jun 5, 2007 | 09:08 AM
EJ7_1998's Avatar
i hope no cause it only leakf after 5 minutes after i turn off the car and about the reservoir getting empty ?
Old Jun 5, 2007 | 09:35 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (EJ7_1998)
It only leaks after 5 minutes because the pressure is building up and the water is still getting up to temp, it probably takes a couple minutes for your thermostat to even open. Your resivor is getting empty because your leaking fluid causing it to use the stuff from the resivor. Bottom line is, if its leaking from your radiator like you say than its your radiator, you need a new one or find out a way to ghetto patch yours up.
Old Jun 5, 2007 | 10:22 AM
EJ7_1998's Avatar
is there an easy way to check if is my radiator cause i look under the car and had the splash guard and it was impossible to c if it was from the radiator it come from the bottom of it but it could be a hose 2 dont u think.thanks
Old Jun 5, 2007 | 10:35 AM
St Jimmy's Avatar
* B A N N E D *
Visualy inspect the hoses and radiator make sure you didnt crack any of the vertical fins. If you have to pull the radiator out to do so.
Old Jun 5, 2007 | 10:48 AM
EJ7_1998's Avatar
vertical fins?
i mean do i have to take our the splash guard to look underneath the radiator?
Prelude209
Oct 11, 2010 12:48 PM
blkcivic310
Aug 11, 2009 08:17 AM
fc3sol
May 4, 2004 10:40 PM
jkn1515
Jul 2, 2003 03:33 PM
kingpen
Sep 25, 2002 01:11 PM
