NEED ADVICE: MY CAR PULLS TO THE RIGHT..HARD!!!
I HAVE A 91 HONDA CIVIC HATCHBACK SI...THE FRONT RIGHT SIDE HAS A 1" SETBACK(THE WHOLE TIRE IS MOVED BACK) IS THERE ANY WAY I CAN FIX THIS PROBLEM..I ALREADY CHANGED THE LOWER CONTROL ARM AND IT'S STILL PULLS TO THE RIGHT!!!
If you switched the lower arm with a new straight unbent one, got an alignment, and it still pulls, look else where. Did the new arm fix the setback? If not then you may have a bent frame. I'd take it to a frame shop and have them measure and make any corrections needed.
Drew96EJ
Dec 30, 2003 07:46 PM
