Stock Swar Bar with ASR subframe brace
Old Jun 4, 2007 | 08:51 PM
UrbanAdolescent's Avatar
Default Stock Swar Bar with ASR subframe brace
I tried searching but didnt find anything. I own a 00 Civic Si and was planning on purchasing the ASR subframe brace. My question is will i still be able to use my stock sway bar with the ASR subframe? Thanks
Old Jun 4, 2007 | 08:57 PM
ke98248's Avatar
Default Re: Stock Swar Bar with ASR subframe brace (UrbanAdolescent)
https://honda-tech.com/zerothread?id=1906897
https://honda-tech.com/zerothread/1452650
Old Jun 4, 2007 | 09:35 PM
Default Re: Stock Swar Bar with ASR subframe brace (ke98248)
In the first post they used an aftermarket one and im guessing from the second one i will still be able to use my stock sway bar. Can anyone confirm this.
Old Jun 4, 2007 | 09:49 PM
ke98248's Avatar
The differences between the AfterMarket sway bars and original ones, (I believe) are just in the type of material used, paint color, and size of the sway bars. So I think you can, yes. Bump for confirmation though.
This is what I plan to do on my 97civic ex coupe.
Old Jun 4, 2007 | 10:26 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UrbanAdolescent &raquo;</TD></TR><TR><TD CLASS="quote">In the first post they used an aftermarket one and im guessing from the second one i will still be able to use my stock sway bar. Can anyone confirm this.</TD></TR></TABLE>
You'll have to get Energy Suspension bushings and universal d-brackets. The stock d-brackets aren't big enough to match up to the bolt holes.
Energy Suspension Part #: 9.5152
http://www.energysuspension.co....html
Summit Racing Purchase Link:
http://store.summitracing.com/...w=sku
Old Jun 5, 2007 | 09:48 AM
PhantomLord's Avatar
Default Re: Stock Swar Bar with ASR subframe brace (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
http://store.summitracing.com/...w=sku</TD></TR></TABLE>
x2. All you need is the bushings and d-bracket. Or you can go with a CTR or ITR rear bar and the stock brackets and bushings for those bolt right up. I did this to mine and used the CTR bar.
Old Jun 5, 2007 | 09:53 AM
Thanks alot guys you cleared up everything for me.
Old Jun 5, 2007 | 10:24 AM
alacard's Avatar
Eran even hooked you up with links for the parts, what a sweetie
Old Jun 5, 2007 | 07:21 PM
ke98248's Avatar
Default Re: Stock Swar Bar with ASR subframe brace (alacard)
nice avatar^^
Midori Green
Feb 12, 2008 11:39 AM
SpoonKid
Oct 26, 2006 11:05 AM
dc2ali
May 30, 2004 11:25 AM
kungfuSiR
Nov 19, 2003 12:14 AM
crazy_ham
Jun 8, 2003 07:49 AM
