what to do? (ps leak)
Old Jun 4, 2007 | 08:14 PM
94c1v1cex's Avatar
Default what to do? (ps leak)
here is a pic of the leak on the rack and pinion drivers side
should i change out the seal and the boot or the whole rack and pinion?
it leaks bad... there are huge puddles in my driveway
Modified by 94c1v1cex at 9:38 PM 6/4/2007
Old Jun 4, 2007 | 08:17 PM
Mr.EM1_EK's Avatar
Default Re: what to do? (94c1v1cex)
pic is not working
Old Jun 4, 2007 | 08:39 PM
94c1v1cex's Avatar
Default Re: what to do? (Mr.EM1_EK)
there it is
Old Jun 4, 2007 | 08:45 PM
chrisw85's Avatar
You'd have to take out the old rack to replace the seal anyhow, and I's pretty sure the seal is cheaper than a new/reman rack. If you have a helms, the time, the patience, the space and beer, by all means just remove and overhaul the rack, get new inner rods, boots, and outter rods call it a day. But if downtime is important, you can just get another rack and rebuild it still to keep as a spare unless you want the core charge back.
Old Jun 4, 2007 | 08:46 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
It is better to replace the whole rack and pinion with a remanufactured one, as there may be worn parts inside the old one.
Old Jun 4, 2007 | 09:00 PM
94c1v1cex's Avatar
Default Re: what to do? (tech8)
where can i find a reman. one?
edit:
it's a 94 ej1 w/d15b swap if that matters
Old Jun 4, 2007 | 09:02 PM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">It is better to replace the whole rack and pinion with a remanufactured one, as there may be worn parts inside the old one.</TD></TR></TABLE>
True that. If there are metal particals circulating which caused seal failure in the first place, replacing the pump may be a good idea too, unless you want to completely overhaul the pump to clean it out. Most rack-pinion remanufactures will only make the warranty valid on the rack if you also replace the pump as well, so keep that in mind, unless you want to convert to a manual rack or make your p/s rack into a manual by looping it.
Old Jun 4, 2007 | 09:05 PM
H22Apowered's Avatar
pretty much any parts house just call around and compare prices
Old Jun 4, 2007 | 09:06 PM
ridin98civic's Avatar
Default Re: what to do? (H22Apowered)
http://www.nopionline.com/nopi...Civic
94c1v1cex's Avatar
Default Re: what to do? (chrisw85)
thanks
Old Jun 4, 2007 | 09:07 PM
94c1v1cex's Avatar
Default Re: what to do? (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">http://www.nopionline.com/nopi...Civic</TD></TR></TABLE>
holy **** that's expensive... thanks for lookin it up
Old Jun 4, 2007 | 09:15 PM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote">
holy **** that's expensive... thanks for lookin it up </TD></TR></TABLE>
Its not that much compared to $900+ for a mercedes or bmw or audi rack. Dont even ask about the newer ones with electronic servo assist, which is a seperate module and costs a lot as well.
Old Jun 4, 2007 | 09:17 PM
94c1v1cex's Avatar
haha i know my gf drives an audi tt turbo... fun as **** but damn! the prices on stuff that stuff is ridiculous
br8crumb
Mar 14, 2016 11:42 PM
tabrubaker323
Apr 9, 2013 04:02 AM
Lewy. Dee Ayy
10
May 20, 2011 06:19 AM
GSRCRXsi
Jul 25, 2010 12:35 AM
BB1vtec
Dec 16, 2005 05:59 PM
