fuel pump wiring
Re: fuel pump wiring (ryanxmx31)
why? there's no benefit to that. anyway if you wire it to the bat. it'll see 12v all the time even with the car on. it's supposed to be seeing 14+ running volts with the car on. so doing that will limit the motor/pump. and you would need a heavy duty switch that can take the repeated abuse of being connected directly to the battery. just do it the way the manufacturer intended and you won't run into any problems.
94delsol6428
12-22-2006 12:51 AM
