another over heating question
Old Jun 4, 2007 | 03:39 PM
j_kevin_ca's Avatar
Default another over heating question
well, since all you guys can tell from the topic, my car is messed up, but i am wondering when the radiator fan suppose to come on? after you start the car?
when i drive around 110-120km mark, the engine doesnt over heat, even tho i drove 2 hours straight, but when i pass 120, it goes fast towards the red line.
would it be the fan thats not working, thats my first guess, and i dont know how to test it. so any suggestions at all?? thx, HT!
Old Jun 4, 2007 | 03:43 PM
hybridmath's Avatar
Default Re: another over heating question (j_kevin_ca)
take a peice of wire and connect the 2 wires that go to the switch on the thermostat just plug one end of the wire into each pin should be 2 of them if the fan dont come on with the car started theres a issue with the wiring if it does its the switch my buddys car is running a 90 integra ls which dosent have that switch so we cut the connector off and twisted the wires fan just stays on while the car is started but shuts off when you turn the car off easy fix
Old Jun 4, 2007 | 03:44 PM
hybridmath's Avatar
Default Re: another over heating question (hybridmath)
if this dont work take a peice of wire and run it directly from the battery to the positive on the fan if it turns on the fan is ok heres a ??? what engine you running and what radiator
Old Jun 4, 2007 | 03:46 PM
j_kevin_ca's Avatar
stock d15b and oem rad
Old Jun 4, 2007 | 04:27 PM
j_kevin_ca's Avatar
ok, the fan is working when i tried the battery to the fan, but from thermo to the fan isnt working... which wire from radiator, should i hook it up to the thermostat if i dont want to use the relay anymore?
Old Jun 4, 2007 | 05:57 PM
slowcivic2k's Avatar
I'd keep the relay, youd probably need a new fan switch and/or ECT sensor for things to work right. Otherwise Id run a toggle siwtch to the cab and toggle the relay and fan on and off as I please.
Old Jun 4, 2007 | 06:43 PM
hybridmath's Avatar
Default Re: another over heating question (slowcivic2k)
so you tried the trick where you cross the 2 wires at the thermosat housing and the fan turns on ?????
Old Jun 5, 2007 | 06:35 PM
j_kevin_ca's Avatar
yeah i tried that, but it didnt work... or do i have to wait for abit for the switch to comeon
Old Jun 5, 2007 | 10:41 PM
hybridmath's Avatar
if you crossed the wires and the fan didnt come on you got an issue with the relay saying that you hardwired the fan and it came on
hondaon18's
10
Jun 4, 2007 07:45 PM
blaster834
Sep 16, 2004 11:52 AM
st0nedstoopid
Jul 11, 2003 12:19 AM
airborne84000
Jun 1, 2003 09:52 PM
.RTErnie
Aug 16, 2002 05:55 AM
