Overheating.....kinda
Old Jun 4, 2007 | 03:06 PM
ernieballbass's Avatar
Default Overheating.....kinda
hello everybody,
my name is chris and i have a 1993 Honda Accord Special Edition. it was given to me for free but had an overheating issue. i patched a small hole in the radiator and purchased a new thermostat.
i drove around and still overheated. to see if the thermostat was the culprit, i just took the thermostat out and drove her around again. this seemed to do the trick but i overheated at idle.
***here is the weird part: if i rev the engine (at a complete stop), the temp goes down.
so to keep from overheating at a long stop light, i just stick her in nuetral and rev until the temp comes down.
....so how do i fix this little issue?
chris
ps: i have owned and fixed aircooled volkswagens. this is my first watercooled "project" car.
Old Jun 4, 2007 | 10:32 PM
Redline130's Avatar
Default Re: Overheating.....kinda (ernieballbass)
I'd say replace the waterpump and see if that helps you out. Is your fan working properly?
Old Jun 5, 2007 | 09:39 AM
hitekper4mance's Avatar
Default Re: Overheating.....kinda (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">I'd say replace the waterpump and see if that helps you out. Is your fan working properly?</TD></TR></TABLE>
Old Jun 9, 2007 | 09:38 AM
b18c1ej8's Avatar
get a new radiator,water pump, coolant hoses, and fan and u should most deff be good
Old Jun 9, 2007 | 08:01 PM
dtapia's Avatar
Default Re: Overheating.....kinda (b18c1ej8)
is your cooling fan comming on ? if not their could be a few things wrong like a possiable fan switch or a fan timer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1ej8 &raquo;</TD></TR><TR><TD CLASS="quote">get a new radiator,water pump, coolant hoses, and fan and u should most deff be good</TD></TR></TABLE>
for the inexperienced guys here.
if he is giving it gas and it cools then the water pump is working.
i read a lot of post and see so much wrong info been giving out it's so damm funny
if your not sure what the problem is then please dont give out incorrect info.
E_F_9
10
Jun 18, 2012 08:14 PM
civic_boii
Sep 29, 2006 04:10 PM
Touge Tuning
Jun 27, 2006 06:17 PM
EGhatched
Mar 14, 2004 04:17 PM
