-- Wierd humming noise whenever I'm in gear, at low RPM's.. What can it be? --
Also I forgot to mention.. Once it starts doing the "noise", It stops once I push the gas, and bring the RPMs up a bit.
try adjusting the clutch pedel when u put in a after market clutch ''centerforce, exedy ect''' most of the time you will need to do that
Does anyone else agree with him and think that it could be the throw out bearing?
^ Also when you say "adjust the clutch" what exactly do you mean? The clutch was installed at a profesional clutch shop back in 05.
I know some one knows what the problem can be.
so the clutch is 2 years old im telling you from what im hearing its the throw out bearing
I know that you said that you think it's the throw out bearing, but I just wanted to get some other people opinions before basing everything off of one persons opinion.
in my expierence i have found that the through out bearing makes noise with the cluctch out and enging running and when you push it in the noise goes away i also know that there is a bearing inside the tranny (unsure which one) but it will make the same noise with the clutch out and go away when you push it in i suggest taking out the tranny and replacing the through out bearing with a honda oe one because it is fairly simple to do and if it dosent go away then i would start looking into new/used trans or a rebuild (i have seen aftermarket bearings make noise out of the box thats why i say oe through out bearing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmath »</TD></TR><TR><TD CLASS="quote">sounds like the throw out bearing to me </TD></TR></TABLE>
x2
x2
Damn, so everyone agrees on Throw Out Bearing..
I was hoping it was something easier, or something that was normal..
About how much is it to get the bearing replaced?
yeah you can do it yourself it is not hard. my em1 has the same problem, im about to just throw in a new clutch too and call it a day. im gonna just pay someone to do it cause im lazy. he is charging me $170, if that gives you some idea of what you will be looking at.
where do you live if your in the area il do it for like $100 if you dont feel like tackling it your self.
MrEm1_ek.. You said your car has the same problem, do you mean it makes the same noise that I described?
And to the last guy, I live in Florida, it says it right under my name but thanks anyways.
Okay someone told me that it could be the tranny just "winding down". I have never heard of this, is this what it can be?
DeeJaaY209
14
Sep 15, 2013 10:40 PM
Solstic
Jun 13, 2012 11:34 AM
99FoxSi
Oct 1, 2002 10:00 AM
