o2 sensor problem
Old Jun 3, 2007 | 09:49 PM
honda5's Avatar
Default o2 sensor problem
[I]I go threw o2 sensors every couple of months. I keep on replacing them. What cause ur car to burn the o2 sensors out real quick.
Old Jun 4, 2007 | 06:36 AM
hondadude's Avatar
Default Re: o2 sensor problem (honda5)
what code are you getting?
What "COLOR" is this Accord?
Old Jun 4, 2007 | 08:15 AM
honda5's Avatar
Default Re: o2 sensor problem (hondadude)
Is a maroon color. 2dr 90 honda accord ex. When i had the codes ran it says its the o2 sensor. How do u know if its burning 2 rich and what would cause it to do that. I just put a o2 sensor on about month ago and nows the lights back on
Old Jun 4, 2007 | 08:23 AM
Damon Reeves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">what code are you getting?
What "COLOR" is this Accord?</TD></TR></TABLE>
Exactly what difference does the color make?
An 02 sensor does not conflict with a vehicle's color.
Old Jun 4, 2007 | 10:58 AM
hondadude's Avatar
Default Re: o2 sensor problem (Damon Reeves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon Reeves &raquo;</TD></TR><TR><TD CLASS="quote">
An 02 sensor does not conflict with a vehicle's color.</TD></TR></TABLE>
"2dr 90 honda accord ex"
Zing..... Zing that went right over your head. LOL
moderators will take points away for asking "WHAT FREAKIN YEAR IS THE CAR?"
Old Jun 4, 2007 | 11:09 AM
hondadude's Avatar
code 1 I'm guessing
I've seen several times the connectors at the top of the passenger side strut tower have poor contacts, and the ECU loses it's connection to the sensor.
Fuel pressure regulator might be leaking a little gas thru the vacum line, usually throws a code 43 also.
worn out spark plugs with a giant gap.
It would be great to hook up a meter/scope and read the O2 sensor voltage swings. .3 volt to .9 volt at idle would be good readings
This link shows the sensor connections;
http://img139.imageshack.us/im...7.jpg
jlpicardq
Jun 11, 2010 07:17 AM
Deadcat
Nov 14, 2005 03:16 PM
Shinbo
Aug 29, 2005 03:12 AM
apok
May 16, 2005 09:52 PM
stehigs321
Jan 1, 2005 07:14 AM
