3 CEL codes...Need help...
Old Jun 3, 2007 | 06:10 PM
llred_devil2001ll's Avatar
Default 3 CEL codes...Need help...
I got these 3 codes this morning and now the car can hardly move...
My battery drained on its own as well...Well here are the codes...thanks
P1298 Electric Load Detector (ELD) Circuit High Voltage
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
Old Jun 3, 2007 | 06:24 PM
yoffer's Avatar
Banned
have you replaced the o2 sensors yet?
Old Jun 3, 2007 | 06:26 PM
Default Re: (yoffer)
No I haven't...
Old Jun 3, 2007 | 06:29 PM
yoffer's Avatar
Banned
That should be the reason why you have two of your three cel. Change the o2 sensors and check the cel with a OBDII scanner and erase the codes.
Old Jun 3, 2007 | 06:37 PM
fiveten's Avatar
Default Re: 3 CEL codes...Need help... (llred_devil2001ll)
Change your eld too
Old Jun 4, 2007 | 12:44 PM
Default Re: 3 CEL codes...Need help... (fiveten)
where is the ELD located??
I've been trying to search...but the search engine here in Honda-Tech kinda sux...
Old Jun 4, 2007 | 12:46 PM
BubblegumTate's Avatar
Check your VSS/ALT fuse. 90% chance that is is blown and your speedo doesn't work.
If this is the case, replace the fuse. If it blows again, there is a wiring harness under the intake manifold that is rubbing and grounding out. You need to fix whatever wires have grounded and tape the harness up so that it is no longer bare and doesn't move around. It's a fairly common electrical problem on 6th gen civics.
Old Jun 4, 2007 | 12:48 PM
Default Re: 3 CEL codes...Need help... (BubblegumTate)
Kool....I'll go check it out right now...
dices543
Oct 1, 2010 11:10 AM
suzuki1211
Dec 30, 2008 11:33 AM
rebuiltSI
Jul 24, 2007 09:07 PM
totalimmortal
Jul 21, 2006 02:24 PM
SpoolinEK
May 21, 2004 02:42 PM
