Prob with clutch on 92 CX. Got some ideas, any help?
Old Jun 3, 2007 | 05:37 PM
LSVTEC426's Avatar
Default Prob with clutch on 92 CX. Got some ideas, any help?
Ok so before i bought my hatch the guy said he was having a prob with the clutch and replaced the slave cylinder and it was good. And it was for about a month. The other day im driving home and lost 95% of my clutch. Checked the fluid and it was low. Checked under the pedal and looks like theres a rubber piece that fluid is leaking from right before the firewall. Would replacing the slave cylinder again fix this prob, or is there a prob somewhere else?
Old Jun 3, 2007 | 06:22 PM
abusedhusband's Avatar
Default Re: Prob with clutch on 92 CX. Got some ideas, any help? (LSVTEC426)
if its leaking at the firewall its the clutch master cylinder, the slave cyl is on the trans.
Old Jun 3, 2007 | 06:27 PM
LSVTEC426's Avatar
Yeah thats what i thought but wasnt sure. Thanks for the info
Old Jun 3, 2007 | 06:57 PM
anytime
Old Jun 3, 2007 | 07:21 PM
Targa250R's Avatar
be professional
Yep, needs a new master cylinder.
I usually recommend replacing both the master and slave as a pair when one fails, because the other usually fails almost immediately afterwards due to the seals being agitated when flushing the system.
Old Jun 4, 2007 | 03:43 PM
LSVTEC426's Avatar
Default Re: Prob with clutch on 92 CX. Got some ideas, any help? (Targa250R)
im going to replace both right now, thanks
Old Jun 4, 2007 | 11:00 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC426 &raquo;</TD></TR><TR><TD CLASS="quote">im going to replace both right now, thanks</TD></TR></TABLE>
When was the slave replaced previously?
If it's been within the last 5 years, I'd just replace the master for now, unless you know for sure that there's a problem with the existing slave.
Old Jun 5, 2007 | 10:26 AM
LSVTEC426's Avatar
Just the clutch master took care of the prob
R81_DC2
Aug 14, 2009 08:54 PM
lsvtec97hatch
Aug 5, 2009 11:21 AM
ricerEJ8
Feb 23, 2008 04:04 PM
sohcondis
Sep 19, 2007 06:22 PM
Ri5e
10
Sep 22, 2004 05:36 AM
