Prob with clutch on 92 CX. Got some ideas, any help?
Ok so before i bought my hatch the guy said he was having a prob with the clutch and replaced the slave cylinder and it was good. And it was for about a month. The other day im driving home and lost 95% of my clutch. Checked the fluid and it was low. Checked under the pedal and looks like theres a rubber piece that fluid is leaking from right before the firewall. Would replacing the slave cylinder again fix this prob, or is there a prob somewhere else?
be professional
Re: Prob with clutch on 92 CX. Got some ideas, any help? (LSVTEC426)
Yep, needs a new master cylinder.
I usually recommend replacing both the master and slave as a pair when one fails, because the other usually fails almost immediately afterwards due to the seals being agitated when flushing the system.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC426 »</TD></TR><TR><TD CLASS="quote">im going to replace both right now, thanks</TD></TR></TABLE>
When was the slave replaced previously?
If it's been within the last 5 years, I'd just replace the master for now, unless you know for sure that there's a problem with the existing slave.
Ri5e
10
09-22-2004 05:36 AM
