problem with my vtec boggs when it engages, or doesn't work at all.
Old Jun 3, 2007 | 01:37 PM
2.2 teg's Avatar
Default problem with my vtec boggs when it engages, or doesn't work at all.
this is weird b/c it will either work fine, or boggs the car when it engages or wont work at all. all my wires are hooked up right. any thing i could try.
Old Jun 3, 2007 | 02:07 PM
mafia's Avatar
Default Re: problem with my vtec boggs when it engages, or doesn't work at all. (2.2 teg)
Do you have good ground to the motor? And how is your oil?
Old Jun 3, 2007 | 02:08 PM
Chris F's Avatar
Default Re: problem with my vtec boggs when it engages, or doesn't work at all. (mafia)
Is your check engine light on?
Old Jun 3, 2007 | 07:46 PM
ethereal2pt2's Avatar
Default Re: problem with my vtec boggs when it engages, or doesn't work at all. (Chris F)
check your oil first..
Old Jun 4, 2007 | 02:14 PM
2.2 teg's Avatar
Default Re: problem with my vtec boggs when it engages, or doesn't work at all. (_BB6)
yes just did oil change, check engine lights on but its vss. i have about 5 grounds on the motor
Old Jun 4, 2007 | 07:56 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2 teg &raquo;</TD></TR><TR><TD CLASS="quote">check engine lights on but its vss.</TD></TR></TABLE>
Did you check for a new code since the bogging started?
Also, my ITR would NOT allow VTEC to engage at less than 15 MPH or so, so it could actually be the VSS that's causing your VTEC to not engage and run like crap at high RPM. I think Hondata fixed that but my stock ECU wouldn't let it engage at low speeds.
Old Jun 4, 2007 | 09:47 PM
2.2 teg's Avatar
ic now i realized my clutch slips at vtec so now im super fawk'd i can launch the hell out of it w/o problems but when vtec hits, there is hella clutch smoke.
my friend also has a h22 in his civic. my motor and the vtec engaugement sound totally different
92nahatch
Sep 13, 2007 07:01 PM
antney
Nov 10, 2005 04:36 AM
veilsides2000
Nov 27, 2004 11:18 PM
dAng! Kris
Sep 17, 2003 07:13 PM
gsrhatch530
Mar 28, 2002 05:10 PM
