91 accord auto to manual conversion??
Old Jun 3, 2007 | 01:06 PM
bigislandc2's Avatar
Default 91 accord auto to manual conversion??
Well a friend and i are doing a manual conversion on his accord, and were almost done, we already installed the trans and cables, moved the mount forward, put the pedals in, cltuch line, ecu..
Is there any thing that we might have missed,
i tried to turn the car over but the car didnt turn???
Help please!!
Old Jun 11, 2012 | 01:09 PM
tcs186's Avatar
Default Re: 91 accord auto to manual conversion??
check all your grounds. i tore apart my D series put it all back and it wouldnt crank turned out to be a bad ground. if that doesnt solve anything check for power at the starter have a buddy turn the key. im assuming it would be 12 volts running into it so wire up a test light. also make sure u wired up the clutch sensor so the ecu knows when u have the clutch down its a little button on the top of the pedal
Old Jun 11, 2012 | 01:27 PM
Arthas's Avatar
^^ out of all the auto2manual swaps ive seen, none used the clutch sensor.
Old Jun 12, 2012 | 01:04 PM
94EG8's Avatar
Seagull Management
You've seen a lot of half assed auto to manual swaps then. It's really not that much more work to wire the clutch start switch up.
Old Jun 13, 2012 | 10:47 AM
HondaAccord_91's Avatar
sell it and buy a manual
Old Jun 13, 2012 | 10:57 AM
Janet@bisimoto's Avatar
Old Jun 13, 2012 | 11:36 AM
jdmcertified909's Avatar
now why would he do that? hes already got it done the tranny is installed and ready to run just got to get the car running. your just gonna end up making him spend more. and its not hes car he said it was his buddies. oh and some people like taking on projects
Old Jun 14, 2012 | 03:30 PM
SlimthHhippie's Avatar
There is two switches on the clutch pedal, one above the other. One is for the starter interlock (depress clutch to start) the other one is to disengage the cruse control. I think the cruse control is on top and the interlock for the starter is on bottom.
Jlm_93accordlx
Aug 22, 2017 10:24 AM
ilikejesus
May 7, 2009 08:46 PM
CD8coupeSiR
Jul 15, 2006 01:06 PM
D_TY3
Sep 30, 2003 09:27 AM
