b18c into a obd1 da teg...couple ?'s
ok guys ive got this swap almost completed...now ive never been a good wiring guru so ive always sought the help of ht...
running p28 ecu
ok so the map on the motor i have is obd1 on the tb...but not the same setup as the org b18a where its mount on the firewall....do i just rewire the new map on the motor w/ the old wires & new plug...or use existing map sensor and leave one on tb unplugged?
and i have 2 evap? sensors near the map...any ideas on hookin those up?
is there any decent wiring swap guides...thanks guys
running p28 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 »</TD></TR><TR><TD CLASS="quote">1. ok so the map on the motor i have is obd1 on the tb...but not the same setup as the org b18a where its mount on the firewall....do i just rewire the new map on the motor w/ the old wires & new plug...or use existing map sensor and leave one on tb unplugged?
2. and i have 2 evap? sensors near the map...any ideas on hookin those up?
3. is there any decent wiring swap guides...thanks guys
1. Doesn't matter. I normally extend the wires and run the one on the TB.
2. Post pics.
3. All over this site.
</TD></TR></TABLE>1. Doesn't matter. I normally extend the wires and run the one on the TB.
2. Post pics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">1. Doesn't matter. I normally extend the wires and run the one on the TB.
2. Post pics.
3. All over this site.</TD></TR></TABLE>
thanks i appreciate it
the 2 things are:
1)evap purge control solenoid valve
2)fuel press regulatory control solenoid valve
which i think i answered my own ?....found the plugs just need to hook them up to proper vac sources...
2. Post pics.
the 2 things are:
88Hatchy
Jun 1, 2009 10:20 PM
