obd-0 to obd-1 map sensor Question
Old Sep 18, 2005 | 05:55 PM
gsrswapdcivic's Avatar
Default obd-0 to obd-1 map sensor Question
searched (since it works now) and only one post is up and no help
i have done the obd conversion the car runs but i get a code 3 and 10 3 is what im worried about its the map sensori cut the old plug off and re-ran some longer wires to my obd-1 map on the top if the throttle body. has any one done this?
any help is awesome
thanks
Old Sep 18, 2005 | 06:36 PM
mmuller's Avatar
Mad Scientist
Default Re: obd-0 to obd-1 map sensor Question (gsrswapdcivic)
is the wiring ok? it doesnt matter wich map you use; same output
Old Sep 19, 2005 | 05:46 PM
Default Re: obd-0 to obd-1 map sensor Question (mmuller)
yeah the wiring is ok. what i did was relocate all the wires to the cab area so it looks clean and i cut the map plug off one by one and soldered them to some more wire just to linghten them. so the connections are fine im going out wed and ******* around with it.
Old Sep 19, 2005 | 08:20 PM
sicsixone's Avatar
is the car turbo'd ?
Old Sep 27, 2005 | 02:31 AM
no its na
whitecvcb16
Mar 22, 2010 08:51 PM
88Hatchy
Jun 1, 2009 10:20 PM
mkcivic
Jun 14, 2007 10:35 AM
ihaterust
Jul 21, 2006 03:53 PM
dpine
Jan 17, 2005 01:22 PM
