D16y8?
Old Jun 1, 2007 | 02:03 PM
team 15's Avatar
Default D16y8?
My brother ran 16.4 at the track with his 97 civic ex. Can he get at least high 15's with street slick and gsr ecu?
Old Jun 1, 2007 | 02:05 PM
excivicboy96's Avatar
Default Re: D16y8? (team 15)
what does he have for mods, and no you can't use a gsr ecu
Old Jun 1, 2007 | 02:08 PM
EM1SiR85's Avatar
From: everywhere., cali,nevada,new york., united states
Default Re: D16y8? (excivicboy96)
you need more than that.
Old Jun 1, 2007 | 02:15 PM
amej8's Avatar
Even with minor bolt-ons, you'd still only run low-mid 16's. High 15's would probably call for more aggressive cams, valvetrain, and a cam gear all with a tune. That should be like 15-30whp and should run you mid-high 15's.
Old Jun 1, 2007 | 02:17 PM
team 15's Avatar
mostly stock with aem intake and 4-1 header. The last owner of this car ran high 15's with back seat remove, light weight crossdrill rotor and light weight rims. Right now this car have the back seat, stock rotor and gsr blade.
Old Jun 1, 2007 | 02:23 PM
Libertariat's Avatar
Ek Forever y0!
He'll spend more money getting his y8 into the 15's n/a than he would turboing it.
Slicks don't just magically make your car faster, your car needs enough power to utilize slicks.
A y8 doesn't have that.
And a gsr ecu would make your car run like ***.
Old Jun 1, 2007 | 03:39 PM
SoullessJapaneseMachine's Avatar
Default Re: D16y8? (ek forever guy)
lol @ gsr ecu
Old Jun 1, 2007 | 03:42 PM
Syndacate's Avatar
Slicks, I/H/E - and him not sucking at driving would put him to like a 15.9
Old Jun 1, 2007 | 06:49 PM
HiProfile's Avatar
Default Re: (amej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amej8 &raquo;</TD></TR><TR><TD CLASS="quote">High 15's would probably call for more aggressive cams</TD></TR></TABLE>
Umm, where would the 2nd camshaft go?
Slicks will help if you have a MAJOR traction issue. With a d16 that has minor bolt-ons you won't have the torque to spin drag radials mcuh in 1st. In other words, you won't shave much time with them, if any. B16's gain time because they usually have to launch very high, and their gearing is much shorter.
Old Jun 2, 2007 | 07:41 AM
jz98ctr's Avatar
you could go and drop about a thousand dollars for I/H/E and gain MAYBE 15-20 horses....or you can spend about $500 and get a bottle of squeeze that would net you at least 50 horses.
Old Jun 2, 2007 | 08:00 AM
Genuine Rolla's Avatar
and it also depends on the driver.
Old Jun 2, 2007 | 08:29 AM
95ProjectEJ1's Avatar
Pick up a Helms, read it, go on turbod16.com and read read read. Then when you are done reading, invest some time searching for turbo parts and invest a small amount of money. I/H/E only on a Dseries is going to get you nowhere.
mengy007
Jan 12, 2007 11:50 AM
DpQInteg
Apr 25, 2006 06:16 PM
Schister66
Jan 17, 2006 06:33 PM
EVLTEK
May 8, 2003 08:49 AM
01nhbgsr
Sep 6, 2002 11:40 PM
