Garret AiResearch turbo?
Old Jun 3, 2002 | 10:58 AM
technine's Avatar
Default Garret AiResearch turbo?
I pulled a Garret AiResearch turbo off a dodge daytona and don't know the spex, but it looks about the same size as an t28 or something like that. Anyone know the spex? Stock actuated Boost, T-what? Anything? TIA
Old Jun 3, 2002 | 12:03 PM
technine's Avatar
Default Re: Garret AiResearch turbo? (technine)
anyone?
Old Jun 3, 2002 | 12:17 PM
Sonny's Avatar
Take it apart and measure everything. If you remove the compressor housing, you'll be able to see what size the wheel is.
The a/r of the exhaust turbine is usually stamped right inside the opening. The a/r of the compressor housing is usually stamped right inside the outlet.
Sonny
Old Jun 3, 2002 | 12:35 PM
paulzy's Avatar
Default Re: Garret AiResearch turbo? (Sonny)
I think the daytonas came with t3 trbos
Old Jun 3, 2002 | 01:16 PM
technine's Avatar
Default Re: Garret AiResearch turbo? (Slow_ass_4dr)
thanks guys, and I also finaly found something on the net that has them rated at a stock 7-7.5psi wastgate setting. I'm gonna try to lengthen the rod to get it down to like 5 or 6psi for daily driving and also once I get them darn thing setup on my motor.
Old Jun 11, 2002 | 09:23 PM
DigitalFusion's Avatar
so was it a T3?
Kid-jdm-teggy
May 1, 2014 04:48 AM
lsnidex
Jan 16, 2009 04:24 PM
scartail
Oct 26, 2004 07:25 AM
PrecisionH23a
Jun 8, 2004 02:23 PM
92lSilude
Oct 7, 2003 07:57 PM
