Turbo questions
Old Apr 30, 2014 | 06:53 PM
Kid-jdm-teggy's Avatar
Default Turbo questions
Im still pretty new to turbos but im confused about A/R numbers and trim.
I bought a car and the guy said its a t3/t4 .48 .62 turbo. So my question is the .48 the exhaust turbine of the turbo and the .62 the compressor turbine? Or is .48 the compressor size and the .62 is the compressor turbine?
Old Apr 30, 2014 | 07:01 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Turbo questions
.48 is the turbine housing size
.62 is the compressor housing size
there's an article on Garretts site explaining aspect ratios, wheel trim, etc. I'll find it and post it.
Old Apr 30, 2014 | 10:21 PM
So do you mean the .48 turbine housing is the size of the hole where the turbine sits? And the .62 is the end of the turbo where it connects to the intercooler piping right?
Old Apr 30, 2014 | 11:23 PM
turbomaniac's Avatar
https://www.turbobygarrett.com/turbo..._tech_advanced
Old May 1, 2014 | 04:48 AM
Schister66's Avatar
Man U FTW
No, these numbers are ratios. They dont denote an actual size or measurement, but rather the aspect ratio between different areas on the turbo. For example's sake a .48ar turbine is much smaller internally than a .82ar (AR = aspect ratio). The .62ar compressor is the same story...
The inlet (or for compressor housings, the discharge) cross-sectional area divided by the radius from the turbo centerline to the centroid of that area.
Do some reading in the FAQ and in the links below...it will clarify your issue.
http://www.myturbodiesel.com/wiki/tu...sel-turbo-faq/
http://www.enginebasics.com/Advanced...explained.html
dustinz_em1
Nov 25, 2007 05:41 AM
scartail
Oct 26, 2004 07:25 AM
p1ccoloz
Jul 26, 2004 10:55 AM
justinbailey
Apr 29, 2004 05:02 PM
DigitalFusion
Jun 13, 2002 07:58 PM
