removing/sanding think amounts of paint????
Old May 29, 2007 | 12:16 PM
ant$missShift's Avatar
Default removing/sanding thick amounts of paint????
Heys, i have a project ef hatch im working that im trying to get paint ready.. the car has seriously been painted 10 times or so and half the the car is coverd in a thick bucket paint . has real thick and nasty drips . its just a mess. i was wondering what my best beat was of getting the car paint ready? should i jsut take a DA sander to it to the metal? or use some sort of striper??
any help would be much apprech. thanks alot
oh also. parts i have started sanding on took down to metal in a spot looks like there is realll slight surface rust under the primer.. its real faint. like if u would have left a bare peice of metal out in the weather for a few days... its light enought to like whip off. but its under the primer so it scares me? is that normal for a lil brownage to be under there??
Modified by ant$missShift at 7:11 PM 5/29/2007
Old May 29, 2007 | 02:31 PM
Default Re: removing/sanding think amounts of paint???? (ant$missShift)
bump
Old May 29, 2007 | 02:53 PM
Pockets's Avatar
bumper stripper, it will remove most non oem finishes. be careful not to get it on plastic aka lights, trim, and moldings. let it set for while then pressure wash it and it probably will make a mess.
Old May 29, 2007 | 06:11 PM
Default Re: removing/sanding think amounts of paint???? (Pockets)
thanks.
any other suggestions or comments on the surface rust looking **** under the primer?
Old May 30, 2007 | 02:10 AM
cxhatch96's Avatar
no, get rid of the surface rust, do it right the first time, or you'll end up with a real bad paint job. Paint, primer, bondo etc. don't like rust too much, and even if they did stick, you'd end up with through rust later.
Old May 30, 2007 | 11:45 AM
Default Re: removing/sanding think amounts of paint???? (cxhatch96)
so jsut take the whole car back down to metal woudl be my best bet?
Old May 30, 2007 | 11:54 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ant$missShift &raquo;</TD></TR><TR><TD CLASS="quote">so jsut take the whole car back down to metal woudl be my best bet?</TD></TR></TABLE>
If you have that many layers of paint on your car, stripping the paint off totally would be your best bet. Remember to use etching primer on your bare metal. And definately make sure all the surface rust is gone.
Old May 30, 2007 | 03:45 PM
vart's Avatar
Default Re: removing/sanding think amounts of paint???? (WihaSi)
Take it to a media blaster...If its as bas as you say, that would be your best bet. then have it etch primed, fix your dents, prime it, block it, prime it, block it again, then wetsand.....then paint. Otherwise your **** will be wavy as expletive.
Old May 31, 2007 | 05:22 AM
Default Re: removing/sanding thick amounts of paint???? (ant$missShift)
what kinda price am i lookin at to get it media blasted?
heres a pick of the car. lol
Old May 31, 2007 | 05:50 AM
92LSVTEC's Avatar
holy ****... ummmm, wow... thats insane... take everything off the car, and have it acid dipped... and e-coated... the last guy that brought me an old shell that was dipped, and e-coated, cast him around $1500
media blast, would be roughly $500-700 id think
Old May 31, 2007 | 06:18 AM
Default Re: removing/sanding thick amounts of paint???? (92LSVTEC)
eh. thats kinda steep.. i dont want to get into so much money.. i think at that point it would be easier for me to buy another shell....
hummm...
coletrain_eg
Paint and Body
Jul 17, 2011 12:22 AM
4g4dcruisin
Apr 20, 2009 02:28 PM
masijdm
Paint and Body
Feb 24, 2009 11:09 AM
B1894civic
Sep 21, 2004 11:55 AM
pelotudo
Sep 17, 2002 02:52 PM
