how much harm can i do on an NA basemap?
Old May 29, 2007 | 08:28 AM
calbert0's Avatar
Default how much harm can i do on an NA basemap?
i did a ported y7/y8 mini me with all the boltons, and kept my p2p ecu. I just got a chipped p28 from xenocron.com He sent me a basemap for all of my modifications, and dsm 450ccs. I want to install the 450's and my p28 because i feel like there is no way it could run worse than my current setup. I dont plan on getting the car tuned imediately. Is this a goood or bad idea?
Old May 29, 2007 | 08:36 AM
smileycvc's Avatar
Default Re: how much harm can i do on an NA basemap? (calbert0)
bad you dont need 450 injectors. If you just install them and dont tune for a while the car will probally run like ****. even with the basemap.
Old May 29, 2007 | 09:07 AM
calbert0's Avatar
even if my basemap was made for 450's?
Old May 29, 2007 | 09:14 AM
B16b-EJ8's Avatar
Default Re: (calbert0)
Why do you even have 450's?
Old May 29, 2007 | 09:15 AM
Boostedb20EH2's Avatar
why dont you just get the car tuned?
Old May 29, 2007 | 09:41 AM
calbert0's Avatar
Default Re: (Boostedb20EH2)
i have 450's because once i get a hot side for my garrett .42/.48 im going to turbo my car. I dont have any tuning equipment/knowledge. I dont want to pay for two dyno tunes one NA, and one Boost, and the closest tuner is over an hour away in Indianapolis. I just want my car to run better and i figured this could help. apparently not.
Old May 29, 2007 | 09:47 AM
If you think your closest tuner is an hour away, go on http://www.xceedspeed.com and you may be suprised..
Modified by Boostedb20EH2 at 2:29 PM 5/29/2007
Old May 29, 2007 | 09:49 AM
Relic1's Avatar
As good as xenocron is a basemap is only a basemap and should be used only to get to the tuner.
get someone local to you to do a quick street tune. You don't need dyno time to get the N/A maps close enough to make sure it's not killing your setup.
check the tuner thread on pgmfi.org for people close to you with this capability.
Old May 29, 2007 | 09:50 AM
Archidictus's Avatar
Unceasing Measure
What constitutes "running like crap" anyhow? I've done mini-me's before and they all ran fine out of the box with a SOHC VTEC ECU. The 450's won't help you at all, nor will an FI tune. If your engine's running badly enough, you probably did something wrong that no amount of half-assed "tuning" will fix.
The ECU is arguably the most important part of your little setup here. If you don't have the money to make it work, you shouldn't have started ******* around with it in the first place.
Old May 29, 2007 | 10:18 AM
calbert0's Avatar
Default Re: (Archidictus)
thanks to everyone for your help except archiDICKtis
Old May 29, 2007 | 10:30 AM
instructor74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calbert0 &raquo;</TD></TR><TR><TD CLASS="quote">thanks to everyone for your help except archiDICKtis</TD></TR></TABLE>
you know kid you don't need to be a dick because someone gives you advice esp when its coming from Archidictus he knows what he is talking about and you could learn a ton from people like him on this site but not with that type of attitude
mxjosh
Sep 15, 2011 08:15 PM
JDMrasta
May 23, 2010 10:59 PM
zexifiedlude
Feb 16, 2006 07:51 AM
Nick H
Oct 14, 2004 09:38 AM
na200whp
Apr 24, 2003 07:29 AM
