Rewiring headlights to Toggle Switch
Old May 28, 2007 | 07:48 PM
gwiffer's Avatar
Default Rewiring headlights to Toggle Switch
Can someone tell me what exactly the low and high beams are on this diagram?
I need to know what pins to jump for lows (D/E or G/I?) and for highs (G/I/J?).
I am unsure as to how the dimmer switch is used.
I have a 90 std hb, so this diagram may not be accurate (crx).
Old May 28, 2007 | 11:18 PM
IP RACING's Avatar
Default Re: Rewiring headlights to Toggle Switch (gwiffer)
why would you want to do that
Old May 29, 2007 | 12:08 AM
Bob_760's Avatar
Default Re: Rewiring headlights to Toggle Switch (IP RACING)
my thoughts exactly
Old May 29, 2007 | 01:43 AM
bobjohnson's Avatar
Should be the same as a crx, lows are the 2 light diagrams, highs are the single light with straight points of light coming out of it (Same as on the dash when you turn highs on (if you have a highs indicator))
So in otherwords, D/E for lows, G/I for highs.
You should be able to follow these lights back through the steering column, and get a 6 post switch with 3 settings, and wire it up accordingly.
The dimmer looks like it works by bridge G/I to either F or J depending on if its supposed to be dimmed low or on full. I would leave the dimmer on the dash if i were you. I assume this is where it is if its like a crx.
Old May 29, 2007 | 09:11 AM
gwiffer's Avatar
Default Re: Rewiring headlights to Toggle Switch (bobjohnson)
The multi switch (w/ levers) was broken when I got my car.
I figured it wouldn't be too hard to wire up a toggle to the headlight switch. I already figured out the turn signals, which were easy. I have no wipers so I didn't want to buy another whole multi switch.
This is all for my street legal drag car (no DD).
I'm also wiring up a push button start and ignition toggle (just for fun). If anyone could help, it is here: https://honda-tech.com/zerothread?id=1990856
Old May 29, 2007 | 09:58 AM
B16acivicsedan91's Avatar
10$ at the most at the salvage yard
Old May 29, 2007 | 02:15 PM
sneakerfern's Avatar
Default Re: Rewiring headlights to Toggle Switch (B16acivicsedan91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16acivicsedan91 &raquo;</TD></TR><TR><TD CLASS="quote">10$ at the most at the salvage yard
Old May 29, 2007 | 02:34 PM
CrxRex's Avatar
Default Re: Rewiring headlights to Toggle Switch (sneakerfern)
Old May 29, 2007 | 07:33 PM
crazykamper's Avatar
bump, very interested as well.... but i really want to wire my high beams onto a toggle switch/dimmer, thanks!
samwam323
Apr 16, 2016 03:43 PM
wickedEFguy
13
Aug 3, 2012 10:03 PM
nieto1991
Dec 15, 2010 04:07 PM
SLeePeR-STaTuS
Dec 8, 2007 06:40 PM
