Fuel line kink w/pics...Problem?>
Old May 28, 2007 | 02:14 PM
digital sol's Avatar
Default Fuel line kink w/pics...Problem?>
Think this would/could cause me issues? Slight kink in the fuel line
Old May 28, 2007 | 02:26 PM
Mr.EM1_EK's Avatar
Default Re: Fuel line kink w/pics...Problem?> (digital sol)
maybe a little, is your gauge reading good pressure still?
Old May 28, 2007 | 02:30 PM
Default Re: Fuel line kink w/pics...Problem?> (Mr.EM1_EK)
yea, still reading 60 @ wot when simply revving from under the hood in neutral'....no pressure guage inside driver area
Old May 28, 2007 | 02:35 PM
Mr.EM1_EK's Avatar
you should be fine, it's a pretty good kink but i don't think it will realy obstruct your flow that much. just drive it around the block see if you feel any difference
Old May 28, 2007 | 02:40 PM
ive been driving it that way for about a month now, i just noticed it about a month ago, i dont drive the car very much'
only issue im having lately is the car studders, feels like mis-fire at partial throttle when under 50% throttle, runs strong in WOT but in city driving on low throttle if i hold the same throttle position and its a low throttle <50% it studders/stammers'
idle pressure- 48
wot- 60
im thinking my addition to adding a new header may be causing it to run a tad lean at partial throttle conditions, but spark plugs are a nice greyish color', it just started doing this lately and the only thing ive changed besides maintenance parts is the header, im upgrading injectors and a few other things before re-tuning and hoping a fresh tune will solve the issue
Old May 28, 2007 | 02:53 PM
PhoebeusFenix's Avatar
I had the stuttering problem in my eg w/ b18 awhile back, changed the fuel filter and it cleared up...
Old May 28, 2007 | 02:54 PM
Default Re: (PhoebeusFenix)
im on a fresh filter
Old May 28, 2007 | 03:04 PM
Mr.EM1_EK's Avatar
what motor do you have, either way i just checked the manual and for a b-series at idle should be between 30-37. d-series is 28-36. so i guess your pressure is a bit high, most likely from the hose, seeing that it sqeezing through would cause higher pressure, makes sense i guess
Old May 28, 2007 | 03:22 PM
nicko360's Avatar
* B A N N E D *
just pick up a new line, i had the same problem, just changed the line from the fuel rail to filter and it was fine
Old May 28, 2007 | 03:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK &raquo;</TD></TR><TR><TD CLASS="quote">what motor do you have, either way i just checked the manual and for a b-series at idle should be between 30-37. d-series is 28-36. so i guess your pressure is a bit high, most likely from the hose, seeing that it sqeezing through would cause higher pressure, makes sense i guess</TD></TR></TABLE>
R motor with a holley 255 fuel pump and aem fpr, stock injectors...throwing on some 310's before next tune, fuel pressure is right where it should be at for my motor/set-up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote">just pick up a new line, i had the same problem, just changed the line from the fuel rail to filter and it was fine</TD></TR></TABLE>
the line looks like a 1 piece line that extends from that point all the way to under the car somewhere', i may just have a shop cut the end of it where its kinked and re-flare it if theres enough line to do it with, just for safe keeping
Old May 28, 2007 | 03:42 PM
Mr.EM1_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol &raquo;</TD></TR><TR><TD CLASS="quote">
the line looks like a 1 piece line that extends from that point all the way to under the car somewhere', i may just have a shop cut the end of it where its kinked and re-flare it if theres enough line to do it with, just for safe keeping</TD></TR></TABLE>
ok well that makes sense then. well that the line that comes from the tank. cutting and re-flaring it would make the most sense. good luck with it.
cadeMFjohnson
Aug 5, 2009 12:57 AM
1SlowSi
Engine Management and Tuning
10
Apr 6, 2009 05:28 PM
PowderB16
Nov 5, 2004 02:50 PM
ActiveAero
Nov 13, 2003 09:35 AM
B17ACRX
Jul 1, 2003 08:22 AM
