boosted b20v ecu help!
Old May 27, 2007 | 03:19 PM
0o_coupe's Avatar
Default boosted b20v ecu help!
Im going to be boosting my b20 vtec, stock b16a head. Im going with a block guard and griddle. Ill be running a GT35R between 12 - 14psi. I have a p06 chipped to a p28 ecu. What am i going to need in terms of engine management and fuel management to make my setup work? Do i also need to change my map sensor??
Old May 27, 2007 | 05:31 PM
primetime's Avatar
Default Re: boosted b20v ecu help! (0o_coupe)
with that much boost a new map sensor is needed unless you run it with check valves but if you do that the motor won't be tuned correctly. I have a b20 vtec with a t3/t4 turbo running 15 lbs. every day, I use hondata s300 for my engine management. but there are a lot of others that are available as well: AEM, Chrome..... just do some research and go with the one that has the features you want, that you can afford, etc.. Also if you don't plan on tuning it yourself talk to your tuner for his advice. Let me know if you have any ?'s about hondata I can try to answer them for you. good luck
chrisfromsrq
13
Jul 30, 2009 12:58 PM
cleanazcoupe
Engine Management and Tuning
Jul 1, 2009 10:55 AM
boostedb18kid
Oct 24, 2007 07:33 PM
0o_coupe
May 28, 2007 06:58 PM
riceracer07
Mar 19, 2007 07:57 AM
