iPod Hookup without car stereo -- only speakers
Old May 27, 2007 | 09:17 AM
ogawa_jiei's Avatar
Default iPod Hookup without car stereo -- only speakers
Edited
Old May 27, 2007 | 09:25 AM
02 accord's Avatar
Default Re: iPod Hookup without car stereo -- only speakers (ogawa_jiei)
Any 2 or 4 channel (depending on how many speakers you have) will work. You would need an adapter to go from the headphones plug into rcas. Hook that up to the ipod and the amp, put the amp's remote wire on a switch (or wire it into the ignition/accessory), and you're all set.
Old May 27, 2007 | 09:32 AM
ogawa_jiei's Avatar
Default Re: iPod Hookup without car stereo -- only speakers (02 accord)
Edited
Old May 27, 2007 | 10:03 AM
noss88's Avatar
subscribed...im interested to know if this works....
Old May 27, 2007 | 10:08 AM
02 accord's Avatar
Default Re: iPod Hookup without car stereo -- only speakers (noss88)
It will. I once hooked up a portable cd player to a sub amp and it worked, so I don't see why this wouldn't.
Old May 27, 2007 | 12:33 PM
.Thomas's Avatar
it works, but the sound quality sucks
true story
Old May 27, 2007 | 01:57 PM
fcm's Avatar
fcm
Old Fart
It is simple, but find a docking port plug to RCA adaptor, for much better SQ, the headphone output is an "amped" signal, the docking port output is a pre-amp signal. 94
Old May 29, 2007 | 07:00 PM
jz98ctr's Avatar
Default Re: iPod Hookup without car stereo -- only speakers (TanCar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TanCar &raquo;</TD></TR><TR><TD CLASS="quote">it works, but the sound quality sucks</TD></TR></TABLE>
X2
Old May 31, 2007 | 04:47 PM
wdesigns's Avatar
You can purchase iPod interface adapters to RCA outputs through PAC or TRC. They also come with power and ground wires so the iPod will be charged while connected to the harness.
Old May 31, 2007 | 04:54 PM
ogawa_jiei's Avatar
Default Re: iPod Hookup without car stereo -- only speakers (wdesigns)
Edited
Old May 31, 2007 | 07:17 PM
fcm's Avatar
fcm
Old Fart
http://www.pac-audio.com/ http://www.pie.net/ http://www.soundgate.com/
The list goes on. 94
Old May 31, 2007 | 07:31 PM
ogawa_jiei's Avatar
Default Re: iPod Hookup without car stereo -- only speakers (fcm)
Edited
Old Jun 1, 2007 | 04:56 PM
JSPECSIR's Avatar
how does the sound quality suck? ive got an amp on the wall in my install bay that i feed my ipod directly into. it sounds fine.
Old Jun 1, 2007 | 08:42 PM
.Thomas's Avatar
Default Re: iPod Hookup without car stereo -- only speakers (JSPECSIR)
Sounds fine and sounds good are two different things
It can sound good with a direct line out from the ipod (dock connector to RCA) or the Red Wine Audio Mod, then with lossless audio encoding, and then a good quailty amp and speakers
Just using the 128kbps encoding is like any crappy burned CD. If thats good enough for you, then do it.
Its not like AM station bad
Old Jun 1, 2007 | 09:47 PM
ender214's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TanCar &raquo;</TD></TR><TR><TD CLASS="quote">Sounds fine and sounds good are two different things
I couldn't say it better. You will be ok as long as you rip your cd's at 320 kbps.
Old Jun 4, 2007 | 03:15 PM
Mark27's Avatar
Default Re: iPod Hookup without car stereo -- only speakers (ender214)
I did such an install once. Sounds okay. 2-ch amp powering 4 speakers.
Here is the pic of the installation:
Here is pic of amp installed, that's the input cable coming out from the hand cream.
Old Jun 4, 2007 | 07:02 PM
m1ndless's Avatar
* B A N N E D *
Default Re: iPod Hookup without car stereo -- only speakers (Mark27)
Personally, I would just get a cheap deck with an AUX input on it... its alot cheaper, and won't look as ghetto as the pics above me..
patrick4588
Audio / Security / Video
11
Feb 18, 2008 09:33 PM
.Kevin.
Jul 1, 2006 02:31 PM
technine
Jul 8, 2005 08:44 AM
Chiller
10
Jan 15, 2005 06:54 AM
jerm001
Apr 18, 2004 08:48 PM
