amp won't turn on!!! HELP
Old Jun 3, 2007 | 04:26 PM
rdeezy78's Avatar
Default amp won't turn on!!! HELP
Ok here it is. I was riding and some how besides the obvious that the terminal was too loose, the negative came off the battery. Fixed that, but now when the car is running I only get about 8 volts back to the amp power wise. But when the car is not running, I get the whole 12.6-8 volts. I'm also getting like 6.2 volts in the remote which is prolly way too much, but I doubt thats my problem with the car running and getting only 8 volts. Any help would be greatly appreciated as we guys with a banger in the car is just not the same with that bump in the trunk. lol
Old Jun 3, 2007 | 07:13 PM
B18C_EJ8's Avatar
You should have 12v at the remote terminal, too... Check the fuse under the hood, too...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">as we guys with a banger in the car is just not the same with that bump in the trunk. lol </TD></TR></TABLE>
WTF does that mean??
Old Jun 4, 2007 | 05:26 PM
rdeezy78's Avatar
Default Re: (B18C_EJ8)
the quote means, that when you ride around with a loud system since like the first day you started driving, too not have a system just doesn't sound right. I guess it's just me.
Old Jun 4, 2007 | 05:28 PM
rdeezy78's Avatar
O yeah, the fuse was the first thing I checked. Good to knw that the remote should also be 12v also. What's throwing me off is the voltage after the car is running as to when the car is off. Power wise.
Old Jun 4, 2007 | 05:31 PM
B18C_EJ8's Avatar
Describe (in detail) your ground.
Old Jun 4, 2007 | 05:33 PM
rdeezy78's Avatar
I have the ground wire mounted to the sub frame inside the trunk by the tail light. It is maybe 15-18 inches long.
Old Jun 4, 2007 | 05:35 PM
B18C_EJ8's Avatar
Try grounding it properly (not to a secondary ground) and tell us what happens...
Sheet metal near the tail light is not an acceptable ground point.
Old Jun 4, 2007 | 05:42 PM
rdeezy78's Avatar
I don't know if it could be called sheet metal. It would be like where your car jack would screw into be mounted tucked away kind of in the rear wheel well. That bracket looking metal, for lack of better words. I would take a pic if I knew how to post it. In front of where the fabric panel is to access the brake light bulbs and such.
Old Jun 4, 2007 | 05:49 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Try grounding it properly (not to a secondary ground) and tell us what happens....</TD></TR></TABLE>
By properly, I don't mean to a piece of metal that's tack welded to the body to hold your jack in...
I mean grounded to an existing bolt in the floor pan of the vehicle, preferably with paint sanded off...
You remind me of the guy that came into my shop with his ground wire stripped back 6" and wrapped around the seatback latch.
Just because it's metal, it doesn't necessarily mean it's a good ground.
Old Jun 4, 2007 | 05:52 PM
rdeezy78's Avatar
that's funny. I got you. I just never had a problem with where it was until now. It's been hooked up for about a year now at the spot I mentioned. Thanks, I'll try another spot.
Old Jun 4, 2007 | 05:54 PM
rdeezy78's Avatar
riddle me this. When I test my voltage though, why do I get more power with the car off than, with the car on????
Old Jun 4, 2007 | 07:38 PM
wdesigns's Avatar
Default Re: (rdeezy78)
Are you testing the battery terminals/amp/wire within the car?
Old Jun 4, 2007 | 07:56 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdeezy78 &raquo;</TD></TR><TR><TD CLASS="quote">that's funny. I got you. I just never had a problem with where it was until now. It's been hooked up for about a year now at the spot I mentioned. Thanks, I'll try another spot. </TD></TR></TABLE>
Post a pic of said ground...
Take the pic, upload to a site like Photobucket.com, then link to it from there, preferably using the [img][/img] tags....
jtfc3s
Audio / Security / Video
12
Jan 2, 2008 02:57 PM
Civic-Crazy!!!
12
Feb 5, 2007 10:22 AM
EOE
Sep 11, 2005 10:22 PM
DrewDown
17
May 12, 2005 08:53 AM
redteg1
Apr 8, 2002 02:43 PM
