d16a6 crank in a d16y8?? will this work??
Old May 26, 2007 | 11:26 PM
1clean_ Ej's Avatar
Default d16a6 crank in a d16y8?? will this work??
I have a d16y8 block that needs a crank. I also have a d16a6 with all internals. So I just need to know will the D16A6 crank work in the Y8 block just that the y8 block will accept the a6 crank? As far as I can see the bore and stroke are exactly the same, and the rods themselves are exactly the same....Im pretty sure?? I just need the crank for a turbo build and I don't wont to buy another crank for the y8. Whats the difference in the thrust washers, rod bearings and main bearings would I need to use or buy those for a y8 or a6 ?? In other words if I get some eagle h-beam rods and srp pistons for a d16y8 will they fit the d16a6 or just clear the valves ?? The deck height on all D16 blocks is the same........right??
So, If anyone sees any problems in this please let me know.
If anyone knows let me know.........thanks guys 1clean_ Ej
Modified by 1clean_ Ej at 2:10 PM 5/27/2007
Old May 27, 2007 | 12:48 AM
Team RS2's Avatar
Default Re: d16a6 crank in a d16y8?? will this work?? (1clean_ Ej)
the d16a6 has a higher deck hieght than most other d series blocks, id phisically bolt the a6 in and clay the motor after you have asembled it to see if it works, happenes with all custom builds if youre not confrotable claying it send it to a machine shop
Old May 27, 2007 | 11:45 AM
1clean_ Ej's Avatar
Default Re: d16a6 crank in a d16y8?? will this work?? (Team RS2)
Old May 27, 2007 | 11:46 AM
Team RS2's Avatar
A6 block higer deck height that Y blocks
Old May 27, 2007 | 11:50 AM
1clean_ Ej's Avatar
anybody wont a d16a6 crank need cash for y8 crank LOL!
Old May 27, 2007 | 12:50 PM
1clean_ Ej's Avatar
Ive been searchin everywhere and found this.......Ill put more on here as soon as I find them! IT sounds like it would work!!
https://honda-tech.com/zerothread?id=984106
http://www.d-series.org/forums...crank
Modified by 1clean_ Ej at 4:08 PM 5/27/2007
Old May 28, 2007 | 02:46 PM
1clean_ Ej's Avatar
bump
Old May 28, 2007 | 02:52 PM
Team RS2's Avatar
the link you posted said some a6's have a 24mm snout and is fully counterweighted,
i thnk thats the one you need?
Old May 28, 2007 | 02:59 PM
1clean_ Ej's Avatar
Yea I know but is a y8 22mm or 24mm snout??
Old May 28, 2007 | 03:03 PM
Team RS2's Avatar
24
Old May 28, 2007 | 03:08 PM
1clean_ Ej's Avatar
How would I go about finding what year and make a6 came with that crank??
also I looked up the part #'s on cranks for a d16z6 and d16a6 they were the same
Modified by 1clean_ Ej at 11:55 PM 5/28/2007
Old May 28, 2007 | 10:28 PM
1clean_ Ej's Avatar
Check is out http://rr-ax.com/bbs/forums/pr...3&mid=
http://cgi.ebay.com/ebaymotors...wItem
So Ive been diggin and found out some stuff. Most all 89-91 d16a6 motors have 24mm snout and the 88 has a 22mm snout. I think the fastest way to see if you have a 22mm or 24mm snout crank.......is by the checking the crank bolt.....12mm is a 22mm snout crank and 14mm is a 24mm snout crank im pretty sure this is right!
I think the motor I got from my buddy is a 91 model. Ill have to see if its got a 12mm or a 14mm crank bolt. Ill also maser it to see if this info is right
Modified by 1clean_ Ej at 3:07 AM 5/29/2007
Old May 29, 2007 | 01:27 AM
HondaPartsHero's Avatar
Technical Hero
why don't you just use the A6 block complete and toss the Y8 one
Old May 29, 2007 | 01:30 PM
1clean_ Ej's Avatar
Default Re: d16a6 crank in a d16y8?? will this work?? (HondaPartsHero)
I wont to do a y8 turbo setup ......not A6
Old May 29, 2007 | 06:41 PM
Technical Hero
yeah but the A6 block is basically the same, its still a 1.6 and unless I've heard it wrong is built much better than the Y8 block
Old May 30, 2007 | 12:54 PM
1clean_ Ej's Avatar
I would just like to do the y8 don't ask me why I just have it in my head to build a y8 for some reason. But I can keep the A6 together if the y8 crank can be reused........I'm going to take it the machine shop to see if its junk or not......I hope its still good without haveing to use over sized bearings if so the A6 can stay together
Efjams24
Jun 17, 2012 07:12 AM
adammilad
May 17, 2010 08:25 AM
hondalowlow
Jan 16, 2006 10:54 AM
Neutex22
Mar 22, 2005 12:42 PM
98civicEX
Jan 26, 2003 05:34 PM
