gsr swap throttle jerk help?
yeah ... wondering if anyone has experienced this problem and if there is a fix to it. i did an gsr swap in my ek bout 2 years ago pulled the motor just got it back in and all set to go. but started jerking at low rpm when i(M) barely tap/on the gas. the tb is NOT stuck, anyone with an idea??? i rem it doing this b4 but only on a rare occurrence. didn't do it earlier today but now it is. help??????
yeah everything is plugged in correctly. no cel. and only 1 way to plug it in on my harness. the way i have it set up. but ill check that rotor if ya think thats it. not sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mastakmk »</TD></TR><TR><TD CLASS="quote">yeah ... wondering if anyone has experienced this problem and if there is a fix to it. i did an gsr swap in my ek bout 2 years ago pulled the motor just got it back in and all set to go. but started jerking at low rpm when i(M) barely tap/on the gas. the tb is NOT stuck, anyone with an idea??? i rem it doing this b4 but only on a rare occurrence. didn't do it earlier today but now it is. help??????</TD></TR></TABLE>
All jerkings from engine are air related man. You must have missed a hose or something check these...
1. throttle gasket and all of its hose
2. Idle air valve control..(some **** like that.) behind the IntakeMan
3. PVC
4. Brake booster valve hose.
5. Intake man gasket
for your problem, you must most definitely have a small air leaks somewhere. I'm pretty sure it's a gasket if you have a low rpm jerking. Big leaks usually jerking at 1-2.4k rpm, small leak from idle to 1.5k rpm.... small leaks are usually from gaskets leak, big leaks are from big gaskets leak and air path from hoses.
GOOD LUCK
3. PVC
GOOD LUCK
trecool44
Mar 12, 2006 05:00 PM
