need help plz
Old May 25, 2007 | 02:25 AM
hema_f117's Avatar
Default need help plz
i have accord 97 EX with F22B vtec engine
i had a problem when i put the gear to (P & N) the RPM starts to bounce from 1000 to 1500 and some times whrn i turn on the AC it stops and become normal.
they told me to clean FITV and IACV and i did but nothing changed
do some one knowes what to do ????
Old May 25, 2007 | 09:07 AM
JimBlake's Avatar
Default Re: need help plz (hema_f117)
Read this whole thread, there's a few more things you can check out or adjust.
https://honda-tech.com/zerothread/1844067
Old May 25, 2007 | 09:45 PM
hema_f117's Avatar
Default Re: need help plz (JimBlake)
dear
thats eactly what i did
need more info about that
thx
Old May 28, 2007 | 06:44 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hema_f117 &raquo;</TD></TR><TR><TD CLASS="quote">thats eactly what i did</TD></TR></TABLE>
Your original post only said AICV & FITV. There's other things in there that can cause your idle surging.
Did you make sure there's no air in the cooling system?
Did you make sure there's no vacuum leaks?
Did you adjust "BASE" idle & then reset ECU & let it learn?
Old Jun 4, 2007 | 09:34 PM
hema_f117's Avatar
how can i make sure there is no air in the cooling system ?
i cant find any vacum leak
Old Jun 4, 2007 | 09:43 PM
JimBlake's Avatar
There should be a small bleeder valve on the thermostat housing. That's a high point where air wants to hang out. Open it a bit to let any air bubbles out.
Then (after driving around) let it cool completely. Squeeze the radiator hoses. You should hear the rattle-pin in the thermostat, but you should not hear any sloshing of liquid. And it sorta feels different when it's full of air (hard to explain).
Old Jun 8, 2007 | 11:45 PM
hema_f117's Avatar
i did the first step man
i checked the cooling ssytem for air
and now there is no air in the cooling system
how can i check for any vacum leaks ?
Old Jun 10, 2007 | 07:40 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hema_f117 &raquo;</TD></TR><TR><TD CLASS="quote">how can i check for any vacum leaks ?</TD></TR></TABLE>The intake manifold is under strongest vacuum when the engine is idling.
Spray brake cleaner around anyplace you suspect is a leak. Intake manifold gasket, throttle body gasket, anyplace. If the idle changes when you spray it, the vacuum leak is where it gets sucked in. Then replace the gasket or whatever's leaking.
hema_f117
May 25, 2007 09:50 PM
djkid17
Apr 17, 2007 07:27 PM
lshatch92
21
Oct 28, 2005 06:38 PM
RedEK
Dec 1, 2004 06:55 PM
E-spec Tuner
May 29, 2004 10:30 AM
