Hondata P72 problem
Old May 24, 2007 | 04:51 PM
PreludePhill's Avatar
Default Hondata P72 problem
When i start rising in RPMs all of a sudden ill get a sudden lose of power,like a really quick hard bog and then the car will come back.When it does this the engine light will flash then go away.Also when i try to read the code the engine light will just stay on,it wont do any long or short flashes.Any ideas?
Old May 24, 2007 | 08:18 PM
ludecz's Avatar
Default Re: Hondata P72 problem (PreludePhill)
Just make sure the car runs ok with stock ecu. Also did you try load different map, or previous map when the car was running good? In datalog there are no error codes? If that won't help you should contact the shop who installed it / tuned it.
GWInquisitor14
Mar 12, 2005 12:02 PM
TokuiAutowerks
Dec 13, 2004 07:29 PM
B18C1CYA
Apr 17, 2004 09:00 PM
ahobbs
Sep 12, 2003 08:41 AM
hybrid901
Jun 16, 2003 05:13 AM
