Quick Fix for Slight Radiator/Coolant Leak?
I recently discovered that I have a slight coolant leak from my radiator. I know the cause but would hate to have to replace the entire radiator so I'm seeking to see if there's a way to keep it from leaking.
The problem or cause of the leak is because I have an aftermarket radiator fan that uses those plastic mounting things where you have to push it through the radiator and clamp it down the other side. Well, I believe that the plastic mounts has now broken or disrupted two of the horizontal "fins"(def?) where the coolant travels. I'm wondering if there's a quick way to patch it up so coolant doesn't leak out anymore. Anything similar to gasket sealants, that can work with coolant?
TIA.
TIA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkertySkerty »</TD></TR><TR><TD CLASS="quote">find the hole and saughter it I dont know how to spell saughter so its saughter to me lol</TD></TR></TABLE>
Or if you cant solder it, you can always purchase a new one for about 65 shipped to your door from RC autoworks i believe.
Yeah I didn't want to buy a new one... I'll try to solder it.. that sound a bit logical. If that doesn't do it, then perhaps I'll have no choice but to replace it. Thanks for the soldering suggestion!
crxaddikt
Mar 25, 2014 11:00 PM
Tim.
17
Jan 30, 2006 09:17 PM
