ITR tranny gears?
Old May 23, 2007 | 06:37 PM
ekBlackHatch's Avatar
Default ITR tranny gears?
This is a lamo question but is a itr tranny 5gears or 6gears i just ordered a itr swap 96spec and plan on putting it in a ek thanks
Old May 23, 2007 | 06:42 PM
Padawan's Avatar
Darth ModerVader
Default Re: ITR tranny gears? (ekBlackHatch)
It's a 5-speed.
Old May 23, 2007 | 06:44 PM
97Ej6mike's Avatar
Only 6 Speeds (in 4cyl honda motors) are the K series; but all D, B, H, F, and lower versions of the K are 5spd.
You find the 6spd in the K20 from the RSX tpye s, and the Europe/UK/Japanesse Civic Type R's (EP3) and also in the new 2006+ Civic SI's. I beleive the TSX's here in the US are the 6spd K series, but im not 100% clear on that, they may be V6's, like the 6cyl Accords in manuel, someone will have to clarify that.
Old May 23, 2007 | 06:49 PM
jsilva's Avatar
Default Re: (97Ej6mike)
The tsx is a k24 with a 6 speed
Old May 23, 2007 | 06:53 PM
Thank you so much guys, also do you know if i have to chip the ecu on the type r when i install it or can i just plug n play and not worry bout it till i can get hondata
Old May 23, 2007 | 08:08 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (ekBlackHatch)
Sure, if you have a type-r ecu.
Old May 26, 2007 | 05:38 PM
Default Re: (ek forever guy)
sweet! Another question anyway to tell if the tranny is equipped with LSD without pulling off the tranny, is there a code or anything that would varify by chance Thanks alot (sorry Im a noob)
Old May 26, 2007 | 05:43 PM
Nongan's Avatar
all type-r trannys have LSD
Old May 26, 2007 | 07:31 PM
Ek Forever y0!
Default Re: (Nongan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nongan &raquo;</TD></TR><TR><TD CLASS="quote">all type-r trannys have LSD </TD></TR></TABLE>
Guess again.
Old May 26, 2007 | 07:50 PM
Team RS2's Avatar
i dunno if it works on itr transmissons but look through the differaential where the axels mount typically if you see a bar going through one side to the other it is NOT a limted slip diff, also there is a stamping on it,
usally that washes of or some shady shops actually stamp it LSD
Old May 26, 2007 | 11:02 PM
FullRaceHonda's Avatar
Default Re: (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
Guess again.</TD></TR></TABLE>
????? all type r's DO HAVE lsd...
and yes you can tell by not tacking off the tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">look through the differaential where the axels mount typically if you see a bar going through one side to the other it is NOT a limted slip diff</TD></TR></TABLE>
basicaly if you can look straight threw the hole where the axles mount then it has lsd, if there is a bar restricting your view threw the hole then its not lsd
Old Jun 4, 2007 | 08:01 PM
WhooHOo my swap came tranny has lsd stamp on it
ps i do think all Rs have lsd unless some boner took it out b4 they shipped it 2 me but i doubt it from my source
BoostKiller
Northwest (Sales)
Jun 9, 2009 08:55 PM
i_am_a_black_man
Mar 17, 2008 05:55 PM
GI8U2racing
Jul 4, 2007 10:28 AM
neo_
Nov 17, 2006 11:10 AM
VTECcnIT
May 11, 2006 08:47 AM
