ITR tranny gears?
This is a lamo question but is a itr tranny 5gears or 6gears i just ordered a itr swap 96spec and plan on putting it in a ek thanks
Re: ITR tranny gears? (ekBlackHatch)
It's a 5-speed.
Only 6 Speeds (in 4cyl honda motors) are the K series; but all D, B, H, F, and lower versions of the K are 5spd.
You find the 6spd in the K20 from the RSX tpye s, and the Europe/UK/Japanesse Civic Type R's (EP3) and also in the new 2006+ Civic SI's. I beleive the TSX's here in the US are the 6spd K series, but im not 100% clear on that, they may be V6's, like the 6cyl Accords in manuel, someone will have to clarify that. |
Re: (97Ej6mike)
The tsx is a k24 with a 6 speed
Thank you so much guys, also do you know if i have to chip the ecu on the type r when i install it or can i just plug n play and not worry bout it till i can get hondata
Re: (ekBlackHatch)
Sure, if you have a type-r ecu.
Re: (ek forever guy)
sweet! Another question anyway to tell if the tranny is equipped with LSD without pulling off the tranny, is there a code or anything that would varify by chance Thanks alot (sorry Im a noob)
Re: (ekBlackHatch)
all type-r trannys have LSD https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (Nongan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nongan »</TD></TR><TR><TD CLASS="quote">all type-r trannys have LSD https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Guess again. |
i dunno if it works on itr transmissons but look through the differaential where the axels mount typically if you see a bar going through one side to the other it is NOT a limted slip diff, also there is a stamping on it,
usally that washes of or some shady shops actually stamp it LSD |
Re: (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
Guess again.</TD></TR></TABLE> ????? all type r's DO HAVE lsd... and yes you can tell by not tacking off the tranny <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 »</TD></TR><TR><TD CLASS="quote">look through the differaential where the axels mount typically if you see a bar going through one side to the other it is NOT a limted slip diff</TD></TR></TABLE> basicaly if you can look straight threw the hole where the axles mount then it has lsd, if there is a bar restricting your view threw the hole then its not lsd |
Re: (Team RS2)
WhooHOo my swap came tranny has lsd stamp on it
ps i do think all Rs have lsd unless some boner took it out b4 they shipped it 2 me but i doubt it from my source https://honda-tech.com/forums/images...s/emsmilep.gif |
