Can i rewire my 97 integra GSR o2 sensor wires?
Old May 23, 2007 | 03:42 PM
Jintegragsr97's Avatar
Default Can i rewire my 97 integra GSR o2 sensor wires?
I was trying out a new cat so i took off my stock 1 which i had to cut off the back o2 wires in order to take off the cat. Now, im wondering if i can just electrical tape the wires back together and it'll still work? I'm also confused on which wires goes with which because theres 4 wires. 1 white, 1 green, 2 black. I dont know which black wire goes with which. Some1 please help. I dont really want to buy a new one because it costs around a 100+ bucks.
Old May 23, 2007 | 03:45 PM
Dartanian's Avatar
Default Re: Can i rewire my 97 integra GSR o2 sensor wires? (Jintegragsr97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jintegragsr97 &raquo;</TD></TR><TR><TD CLASS="quote">I was trying out a new cat so i took off my stock 1 which i had to cut off the back o2 wires in order to take off the cat. Now, im wondering if i can just electrical tape the wires back together and it'll still work? I'm also confused on which wires goes with which because theres 4 wires. 1 white, 1 green, 2 black. I dont know which black wire goes with which. Some1 please help. I dont really want to buy a new one because it costs around a 100+ bucks.</TD></TR></TABLE>
I would solder and use heat shrink at the bare minimum. The two black wires are both grounds...they can be interchanged.
Old May 23, 2007 | 03:47 PM
Rainmaker's Avatar
Don't know about the electrical tape, just because of the heat in that area. Perhaps someone else can help with that part.
Regarding the two black wires, they are interchangeable. One is a ground for the heating element, the other is the ground for the actual sensor.
Old May 27, 2007 | 12:31 PM
VTEC_Du_Ma_Mai's Avatar
hi im having a similar problem: the o2 sensor pins got pulled out and i need to know which wires go where. im not sure but i think the green and white go on the top and the black ones are below. or if someone could take a pic of their primary o2 sensor that would be cool.
Old May 27, 2007 | 12:36 PM
numbnuts22715's Avatar
Default Re: (VTEC_Du_Ma_Mai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_Du_Ma_Mai &raquo;</TD></TR><TR><TD CLASS="quote">hi im having a similar problem: the o2 sensor pins got pulled out and i need to know which wires go where. im not sure but i think the green and white go on the top and the black ones are below. or if someone could take a pic of their primary o2 sensor that would be cool. </TD></TR></TABLE>
If you are holding the o2 sensors harness connection thing, with the tab pointing straight up, the wires go
black black
white green
Does that help?
Old May 27, 2007 | 12:48 PM
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">If you are holding the o2 sensors harness connection thing, with the tab pointing straight up, the wires go
black black
white green
Does that help?</TD></TR></TABLE>
yea thanks a lot. so basically i have the wires upside down.
godluvstegs
Dec 15, 2010 07:08 PM
JDM kid
16
Jan 17, 2005 07:07 PM
Phatch99
Aug 3, 2004 12:51 PM
pregunta
May 30, 2003 09:35 AM
zojirushi
Nov 18, 2002 09:39 AM
