Tranny Fluid Change help
After draining the plug I took the 10mm bolt off the VSS to fill; I've done this on other trannies before, never this particular one. The sensor did not want to budge.
So then I took off the two 10mm that hold the sensor onto the sensor component on the tranny. I pulled and the top part came off exposing the sensor probe. Being desperate to fill the tranny I pulled off the little probe to see if I might be able to fill it, after seeing that I could not I put everything back together.
Two questions.
1) Could I have messed something up by doing that?
2) What's the fill plug size?
Thanks.
Two questions.
Thanks.
I've already searched, even on majestic jerk.
I can't make out the part #, I don't have a socket set and would like someone to just give me the head size to the tranny fill bolt so I can go and grab that socket.
It's defintely a socket bolt.
I think you might be thinking of the drain bolt.. which doesn't require a socket, and that's a 3/8 not 1/2.
The fill is pretty big, either 15/17/20 or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnoPuntoCinco »</TD></TR><TR><TD CLASS="quote">
Two questions.
Thanks.</TD></TR></TABLE>
1) As long as you didn't fiddle with it too much, it should be ok. I've opened mine when I had no idea how to fill the trans fluid and its still good.
B) 17mm
If the whole VSS won't budge just keep trying to spin it left/right. Or tap it gently with a hammer.
Two questions.
B) 17mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
B) 17mm
If the whole VSS won't budge just keep trying to spin it left/right. Or tap it gently with a hammer. </TD></TR></TABLE>
Firstly, thanks for both answers.
It's on there good... I tried to feel under the vss to see how it's connected to the tranny... and it really feels like they are together as if they are one.
Thanks again.
B) 17mm
Thanks again.
aser1z
Sep 7, 2005 08:17 PM
nfinitecc
Dec 3, 2004 03:47 PM
team2n1hatch
Jun 30, 2003 04:00 PM
