Quaife Install ? Searched
Old May 22, 2007 | 07:17 PM
WVTURBOCRX's Avatar
Default Quaife Install ? Searched
I just got a new Quaife and Syncros and about to try and let my brother (who is a Auto Tech) install everything. However I want him to refer to a write up I thought was on here that I can not find. Does anyone know where a good write up is?
It's for a B16A Y1 Cable Tranny.
Also what bearings need to be replaced?
Any help would be great.
Old May 23, 2007 | 09:46 AM
WVTURBOCRX's Avatar
Default Re: Quaife Install ? Searched (WVTURBOCRX)
Does anyone know a show arround Morgantown, WV that instals these? It's also about 1 hour from Pittsburg.
Old May 23, 2007 | 11:54 AM
IN VTEC's Avatar
You have to remove the VSS ring gear and transfer it to the Quaife. Make sure that you note which way the gear is oriented with respect to the direction of the teeth of the final drive ring gear.
To remove the VSS ring gear, you have to remove the diff bearing on that side otherwise it'll hang on the bearing.
Replace both diff bearings. Use the 80mm ball bearings instead of the roller bearings. They're easier to set clearance.
Reshim the differential with a single 80mm shim on the gear housing side.
Old May 23, 2007 | 05:34 PM
WVTURBOCRX's Avatar
Default Re: Quaife Install ? Searched (IN VTEC)
Thanks for the help, that is exactly what I need to know.
Looking at the Majestic Honda web site or Acura parts what part is that? Year & Make? I thought it may be the 93 Teg?
The motor / tranny is a B16A1 with Y1 LSD tranny.
Thanks again, Jeremy
Old May 23, 2007 | 06:50 PM
4g hatch's Avatar
once you put the aftermarket diff in what is your plans for the stock one cause im may be looking for one
Old May 23, 2007 | 08:07 PM
IN VTEC's Avatar
2 x 19
1 x 14 (after you know what size you need)
and then as necessary
1 x 24
1 x 18
Old May 24, 2007 | 04:43 AM
WVTURBOCRX's Avatar
Default Re: Quaife Install ? Searched (4g hatch)
I will sell you the original LSD when we get it out. Just for a few buck and shipping. PM me on here so I can save your info.
Old May 24, 2007 | 04:45 AM
WVTURBOCRX's Avatar
IN VTECH. Thanks for the support. Perfect....
I am trying to order the part but what damn make & model do you put in for the B16A1 LSD Y1 Tranny?
Thanks one more time.
Modified by WVTURBOCRX at 5:46 PM 5/24/2007
Modified by WVTURBOCRX at 5:47 PM 5/24/2007
Old May 24, 2007 | 05:47 PM
4g hatch's Avatar
i think that the y1 should be the same as the ls tranny. besides the ys1 i think all the cable trannys are the same.
Old May 24, 2007 | 06:24 PM
IN VTEC's Avatar
Default Re: (4g hatch)
I believe the LS Y80, S4C, and YS1's all use the same differential bearing part number. They're the thinner ones.
If the diff bearing is too thick, the diff won't clearance properly. It'll be too tight.
Old Aug 22, 2007 | 02:23 PM
dannydos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">2 x 19
1 x 24
1 x 18</TD></TR></TABLE>
whats 18 & 24???
what shims for a 96 gsr...with quaife..thanks
Old Aug 22, 2007 | 06:21 PM
IN VTEC's Avatar
Default Re: (dannydos)
#18 and #24 are the clutch housing mainshaft seal and bearing. They're commonly referred to as teh input shaft seal and ball bearing.
As for the shim, you have to measure the clearance with the shim you already have, and if it's out of spec, then measure the shim you have and reference the chart in the manual to determine the next shim you should try. It can take a few tries to get it right. I typically stock most of the 80mm shim sizes to avoid the hassle of waiting for parts.
Old Aug 25, 2007 | 04:06 AM
dannydos's Avatar
Default Re: (IN VTEC)
to bad you can't use the thrust shims...but i don't see why not...
Old Aug 25, 2007 | 10:13 PM
IN VTEC's Avatar
It is a thrust shim.
IN VTEC
Aug 24, 2010 03:44 PM
HT Chaplain
May 3, 2005 03:26 PM
Wes V
Oct 25, 2003 07:37 AM
V-SPEC 1
Jan 26, 2003 06:10 PM
jdmciviceg
Feb 2, 2002 11:25 AM
