Yokohama Parada Spec-2?
Old May 21, 2007 | 10:11 PM
LLiieemm's Avatar
Default Yokohama Parada Spec-2?
Do you like the tires "Yokohama Parada Spec-2"?
Old May 21, 2007 | 10:19 PM
pos_cd5's Avatar
Default Re: Yokohama Parada Spec-2? (LLiieemm)
paradas give mediocre performance, its more AIM'ed toward people who want a tire size to fit large rim application on sport compacts. ex: thin, large diameter tire.
you should go with the ES100s
Old May 21, 2007 | 10:34 PM
::MYCORD::'s Avatar
Default Re: Yokohama Parada Spec-2? (pos_cd5)
There are totally better tires for the money such as the Dunlop Direzza DZ101's.
Old May 22, 2007 | 09:57 AM
chido's Avatar
A friend of mine has them and the performance is just OK. Expensive tires that just look good.....No gets the vote
Old May 22, 2007 | 10:48 AM
nsxtasy's Avatar
H-T Order of Merit
They are CRAP.
Old May 23, 2007 | 05:35 PM
HondaF1Fanatic's Avatar
But mommy, they look so pretty.....
Jon
Old May 24, 2007 | 06:35 PM
supersteven's Avatar
They're junk. SPT's look sweet too and they're a way better value.
Old May 25, 2007 | 07:55 AM
DaveSi677's Avatar
Default Re: (supersteven)
They are overpriced crap!
Old May 28, 2007 | 08:00 AM
slammed00si's Avatar
Default Re: (DaveSi677)
wet weather they are downright dangerous unless they are new. they wear so quick you will be buying them all the time(even with a good alignment). they are mediocre in dry weather handling in my opinion. so i vote no.
Old May 28, 2007 | 07:06 PM
DesioMedia's Avatar
Why does tire rack rate these so well. They give them better ratings than the SPT on every test?
Old May 29, 2007 | 09:27 AM
backwoods's Avatar
When I had mine they didn't last for ****
Old May 29, 2007 | 06:19 PM
-Todd-'s Avatar
Default Re: (backwoods)
Those tires are horrible.
Old May 29, 2007 | 10:57 PM
THE_EM1's Avatar
I had them for a while and never had any issues with them. A little on the noisey side, but none the less a good tire for my standards. I'd buy another set.
Old May 29, 2007 | 11:54 PM
Voyage34's Avatar
Default Re: (DesioMedia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DesioMedia &raquo;</TD></TR><TR><TD CLASS="quote">Why does tire rack rate these so well. They give them better ratings than the SPT on every test?</TD></TR></TABLE>
what rating are you referring to? the user survey? or their actual road tests?
unless ive missed it, they never compared the two in a back-to-back test. through some extrapolation however, the tests suggest they are far worse than the spt.
*roundabout logic alert*
the Parada tested similar in the dry and better in the wet than the Dunlop FM901, which in another test was bested almost across the board by the Kumho 712, which in another test was bsted across the board by the Yokohama es100 which about par with the SPT in the dry and obliterated by the SPT in wet conditions.
spt&gt;es100&gt;712&gt;fm901&gt;parada
Old May 30, 2007 | 12:26 AM
pos_cd5's Avatar
Default Re: (Voyage34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">
spt&gt;es100&gt;712&gt;fm901&gt;parada</TD></TR></TABLE>
lmao! i like the way you think
Old May 30, 2007 | 05:57 PM
DesioMedia's Avatar
Ok, wow I feel stupid now. The numbers that are published below the description are the survey averages not based on acctual test results. I though thoes numbers were published by tirerack as grade on their own tests. My bad
Old May 30, 2007 | 08:16 PM
Voyage34's Avatar
no worries, i had to be corrected on that once too
Old May 31, 2007 | 02:34 PM
DesioMedia's Avatar
They just look so official
Guitargeak99
Honda Civic (2001 - 2005)
Apr 1, 2019 03:11 AM
spenceyd
Honda Civic (2006 - 2015)
Aug 14, 2017 04:38 PM
nsxtasy
Mar 1, 2006 09:30 AM
B16ADelSol
May 18, 2004 08:38 PM
Audi RS4
10
Aug 27, 2002 08:04 PM
