Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
window stuck
Old May 21, 2007 | 11:54 AM
ryan_61684's Avatar
Default window stuck
Today my passenger side window wont roll down, WTF? All other windows will. could it be a wire or a fuse possibly the motor fucked up? I dont really know what to look for once i take the door panel off
Old May 21, 2007 | 02:31 PM
katzenjammer84's Avatar
My guess is it's a bad switch. You can confirm this is you can roll down the window from say the passenger side, but not the drivers side. If it's not, the motor might have come off the track, or there may be something interfering with operation.
I doubt the motor flat out died, it usually has a long agonizing death and just doesn't quit...at least, that's what I've noticed on Hondas.
I doubt it's a fuse because you would have most likely noticed other items not working.
Old May 22, 2007 | 01:47 PM
ryan_61684's Avatar
Default Re: (AcuraFanatic)
Ive tried rolling it down using the passenger switch and it wont budge at all, i put my ear to the door and listened for something to sound out of place and i hear nothing. Guess Ill be taking the door panel off tomarrow. Im just glad its stuck up and not down....that would be very shitty.
Old May 23, 2007 | 03:30 AM
4DRCivicEX's Avatar
did yo umake sure the lock out switch isn't on?
Old May 23, 2007 | 08:32 AM
dmorris05's Avatar
Default Re: (toyomatt84)
incorrect if the lock out switch is pressed you cannot roll it down from either side i just tried it on my 04 to double check.
Old May 23, 2007 | 08:42 AM
Harlowe's Avatar
Function>Fashion
Default Re: (dmorris05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmorris05 &raquo;</TD></TR><TR><TD CLASS="quote">incorrect if the lock out switch is pressed you cannot roll it down from either side i just tried it on my 04 to double check.</TD></TR></TABLE>
True story.
My passenger side window moves some when going down, I Don't know what it is
Old May 23, 2007 | 08:53 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: (4DRCivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRCivicEX &raquo;</TD></TR><TR><TD CLASS="quote">did yo umake sure the lock out switch isn't on? </TD></TR></TABLE>
As silly as it sounds, i've done that before. I'd knocked it by accident and was about to pull the door card off when i noticed it
Old May 23, 2007 | 09:02 AM
dmorris05's Avatar
Default Re: (ONLYuk7thGen)
i worked at a dealership in service. you'd be surprised how many people came in for the window lock. they wanted a mechanic to look at there car because the pass window would not go down.... i pressed the button and bam no more problem
Old May 23, 2007 | 02:57 PM
ryan_61684's Avatar
it came off track, ******* ******** dont know how to shut a door easy. Thanks for the help guys
aresjay
Oct 17, 2018 01:36 PM
einzelherz
Dec 16, 2011 02:58 PM
TRYLSTEG808
Mar 3, 2008 05:55 PM
steven975
Honda S2000
May 3, 2004 04:37 PM
funkylemons
Audio / Security / Video
Nov 27, 2002 10:50 AM
