2-step? what is it?
Old May 21, 2007 | 09:01 AM
VTEC_PRODUCTION's Avatar
Default 2-step? what is it?
http://www.youtube.com/watch?v...earch=
anyone know what they mean by 2-step here???
Old May 21, 2007 | 09:06 AM
t0p_sh0tta's Avatar
Default Re: 2-step? what is it? (VTEC_PRODUCTION)
It's a dance for people that can't dance.
It's basically a temporary rev limiter (set lower than normal) used to aid in launching.
Old May 21, 2007 | 09:07 AM
Default Re: 2-step? what is it? (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">It's a dance for people that can't dance.
It's basically a temporary rev limiter (set lower than normal) used to aid in launching.</TD></TR></TABLE>
haha ok good one...but why is it so hella loud?
Old May 21, 2007 | 09:09 AM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">
haha ok good one...but why is it so hella loud?</TD></TR></TABLE>
It's not the two step that's loud, it's propable the straight pipe or open header they're running.
Old May 21, 2007 | 09:43 AM
rmcdaniels's Avatar
It's loud because it's not 2-step, it's anti-lag.
2-step is just a rev-limiter that is set up to let you launch at a high RPM. Anti-lag adds a timing retard to your 2-step that essentially retards the timing until the exhaust valves are open, causing an uncontrolled explosion that greatly elevates the temperature and pressure in your exhaust manifold, effectively spooling your turbo and building boost with no engine load. I have used it before on my car, it sounds like someone chucked a bunch of hand grenades into your motor. It will scare the crap out of you if you're not expecting it.
Old May 21, 2007 | 09:58 AM
t0p_sh0tta's Avatar
Default Re: 2-step? what is it? (rmcdaniels)
aka, the loud popping/backfiring you hear when drag cars are getting ready to leave the tree.
Old May 21, 2007 | 06:05 PM
silk106's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">It's loud because it's not 2-step, it's anti-lag.
2-step is just a rev-limiter that is set up to let you launch at a high RPM. Anti-lag adds a timing retard to your 2-step that essentially retards the timing until the exhaust valves are open, causing an uncontrolled explosion that greatly elevates the temperature and pressure in your exhaust manifold, effectively spooling your turbo and building boost with no engine load. I have used it before on my car, it sounds like someone chucked a bunch of hand grenades into your motor. It will scare the crap out of you if you're not expecting it.</TD></TR></TABLE>
it will defitnitly make the crowd at street races jump back.
Old May 21, 2007 | 06:15 PM
94typeR's Avatar
Default Re: 2-step? what is it? (silk106)
its only cool when its used for performance, not to scare people
Old May 30, 2007 | 09:52 AM
boost4life's Avatar
ive been trying to learn about anti lag and that how do u engage it
Old May 30, 2007 | 09:53 AM
boost4life's Avatar
jus read that u use a simple button
Old May 30, 2007 | 03:17 PM
Chef Andre's Avatar
HT's TOP CHEF
Default Re: (boost4life)
Perfect explanation.
Old May 30, 2007 | 05:04 PM
IE IL IP IH's Avatar
""It's basically a temporary rev limiter (set lower than normal) used to aid in launching. ""
simple.
Old May 30, 2007 | 05:23 PM
97Ej6mike's Avatar
Now hows it turned off? Some sort of motion sensitive sensor that detects when the car's clutch has been engaged? or when the car starts to move at any point?
Old May 30, 2007 | 06:50 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Now hows it turned off? Some sort of motion sensitive sensor that detects when the car's clutch has been engaged? or when the car starts to move at any point?</TD></TR></TABLE>
on my friends race car he has a button on the shift ****, when he holds it down, it engages the 2step, but when he releases, the car goes back to regular
Old May 30, 2007 | 08:58 PM
rmcdaniels's Avatar
Pretty much any kind of switch will do it, some people mount a switch on the clutch pedal assembly. I have a programmable ECU, so you can just tell it that anti-lag is on at any RPM over xxxx while speed is 0.
2wheelhunter
Jan 24, 2007 08:53 PM
teamvirus
25
Dec 31, 2006 02:48 PM
hatchback
May 28, 2003 09:46 AM
