BAD CLUTCH.........?
Old May 20, 2007 | 07:35 PM
MR_FIX_IT's Avatar
Default BAD CLUTCH.........?
Car: 96 Acura Integra
Engine: B18b1
With the car off it will go into gear...........but after he starts it it will not go into gear........his clutch peadal feels fine................i wanna say he needs a new clutch but not for sure..........................any thoughts....?????????
Old May 20, 2007 | 08:16 PM
MR_FIX_IT's Avatar
Default Re: BAD CLUTCH.........? (Purple_GS-R)
up
Old May 20, 2007 | 09:31 PM
MR_FIX_IT's Avatar
to the top
Old May 21, 2007 | 08:14 AM
JimBlake's Avatar
Watch the slave cylinder & throw-out lever while someone works the clutch pedal. It should move about 12mm or so. If that's OK, then the hydraulic system is OK. That leaves problems inside the bellhousing...
Old May 21, 2007 | 08:43 AM
MR_FIX_IT's Avatar
bump
Old May 21, 2007 | 08:55 AM
MR_FIX_IT's Avatar
up
Old May 21, 2007 | 10:53 AM
deftonerider's Avatar
adjust clutch, if that doesn't work pull tranny
Old May 21, 2007 | 11:17 AM
MR_FIX_IT's Avatar
Default Re: (deftonerider)
any one else
Old May 24, 2007 | 08:14 AM
Crispy's Avatar
Default Re: (Purple_GS-R)
Like the first post said, check the slave and hydraulic system first, no sense it buying a clutch and taking the tranny off if you dont have to, start with the easy stuff to diagnose.
Old May 24, 2007 | 09:05 AM
JimBlake's Avatar
Default Re: BAD CLUTCH.........? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Watch the slave cylinder & throw-out lever while someone works the clutch pedal. It should move about 12mm or so. If that's OK, then the hydraulic system is OK. That leaves problems inside the bellhousing...
</TD></TR></TABLE>Do you need help finding the throw-out lever?
Old May 24, 2007 | 09:13 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Purple_GS-R &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Jim wasn't trying to misguide you...
Move the rubber boot covering the slave cylinder-to-lever arm area and inspect.
Old May 25, 2007 | 12:09 AM
MR_FIX_IT's Avatar
Default Re: BAD CLUTCH.........? (EE_Chris)
i didnt think he was trying to missguide me.....i was just wanting to see if there was any other opinions...........but yea its defanintly the pressure plate/clutch, when its in gear u can feel it grinding and u hear metal to metal contact.......thanks for the input guys
Old May 27, 2007 | 12:14 AM
MR_FIX_IT's Avatar
found the problem
Old May 28, 2007 | 06:48 PM
JimBlake's Avatar
Ouch. Yeah, that'll cause the problem...
Old May 29, 2007 | 12:04 AM
MR_FIX_IT's Avatar
what do u think would cause that
Old May 29, 2007 | 05:30 AM
JimBlake's Avatar
Too many shocks? I don't know for sure. I wouldn't be able to tell the difference between abuse vs. defective part.
Keeper1343
Sep 1, 2007 07:52 AM
Felt.2
Aug 13, 2006 03:47 PM
LSEGHATCH
May 2, 2006 06:18 AM
jazz1320
Aug 2, 2005 01:27 PM
sharktlp
15
Sep 20, 2004 02:11 PM
